ecu fuse keeps blowing
Old Oct 7, 2001 | 10:40 AM
One8Hatch's Avatar
New User
Default ecu fuse keeps blowing
hey, im using a 91 ecu with a 95 ls motor in a 91 h/b Si, so does that hurts performance? also i purchased a ecu wire harness coverter kit from place racing so i can run a 95 ls obd1 ecu, but everytime i turn the key over one click, the ecu fuse blows with the 95 b18b ecu, i dont know why it does it, right now im running a 91 non-obd ls distributer and i also have the injector resistor, and theres this one 2 wire plug on the back of the motor that doesnt go any where. and sugestions on why i blow a ecu fuse. i called place racing and they said that they are %110 positive that they have the right connections, and they re checked it 5 time before sending it out to me, I HATE WIRES, so any sugestions? thank you
Old Oct 7, 2001 | 02:27 PM
my_slow_civic's Avatar
Default Re: ecu fuse keeps blowing (One8Hatch)
I guess I may be a little behind on my info. But I did not know you could run a SOHC motor ECU with a DOHC motor. All the ignition/timing points etc. are different. Or so i though
Old Oct 7, 2001 | 04:29 PM
Blown90hatcH's Avatar
If you are blowing the ECU fuse.....you have a short in that chitty place harness.
Old Oct 7, 2001 | 06:47 PM
One8Hatch's Avatar
New User
Default Re: ecu fuse keeps blowing (kbslacker)
sorry i ment that its the 91 integra ls ecu, thanks
Old Oct 8, 2001 | 07:14 AM
Stinkalope's Avatar
New User
Blown90hatch is most likekly right, I would not think the ecu would affect your setup as much as you would think. I have heard some stories about the harnesses.
94SuperLudeSI
Apr 20, 2008 06:10 AM
sixtodc2
Jun 14, 2006 07:40 AM
killa_lude
Jan 10, 2004 12:45 PM
