brake system light come on
Thanks, i'm going to check it later and I just want to say more it, the light will turn off if i put the gear to N or to P so I hope it is some thing about the light ball.
if the brake system becomes airbound that light will come on i know if the rears are drum and way out of adjustment and there is a real low pedal the light will come on it shoudnt come on for a bulb out
The same happened to my mates civic coupe. His handbrake used to work fine, but the handbrake sensor went bust, thats why the dash light for the brakes was on all the time. He had the sensor replaced and its back to normal now.
TTT
The bulbs are ok, but I open the reserve cap it was some green thing in the brake fluid so I pump most of the fluid in the tank out and there is some green thing on the filter so I get the filter to clean, put every thing back and the light was still on, but one day after that the light is back to normal, so maybe is time to change brake fluid.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdm Oz »</TD></TR><TR><TD CLASS="quote">The same happened to my mates civic coupe...</TD></TR></TABLE>
Is your civic bark syslight on all the time after you star the engine or after a while of driving? Mine is after a while of driving, so I want to make suer if i have this problem next time i know what to do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigLoadChoakHard »</TD></TR><TR><TD CLASS="quote">if the brake system becomes airbound that light will come on i know if the rears are drum ...
I have real disk and the ped are still good.
The marks on the side of the brake resevouir are shy of the proper "full" level. You are supposed to fill it up as high as you can.
My Integra is cranky that way, she'll whine about the brake system unless I fill her up past all the way.
