Motor oil: Anyone use 0W30?
Old Feb 5, 2004 | 11:26 AM
capcon83's Avatar
Default motor oil question 0W30
i herd that 0W30 is the best thing to get for our motors and was wondering if that was correct.
mobil 1 just came out with 0W30 full synthetic oil and i was wondering if anyone tryed it and if anyone recommend using 0W30 instead of 5W30
thanks in advance
Old Feb 5, 2004 | 11:32 AM
julow's Avatar
Default Re: motor oil question 0W30 (capcon83)
I use AMS 0w30. Great stuff.
Old Feb 5, 2004 | 11:35 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by capcon83 &raquo;</TD></TR><TR><TD CLASS="quote">i herd that 0W30 is the best thing to get for our motors and was wondering if that was correct. </TD></TR></TABLE>
Try reading your owners manual next time.
The only 0W-30 i would suggest would be the German made Castrol Syntec, it tests out the same as the other 5W oils in terms of viscosity.
Old Feb 5, 2004 | 11:40 AM
capcon83's Avatar
Default Re: motor oil question 0W30 (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
The only 0W-30 i would suggest would be the German made Castrol Syntec, it tests out the same as the other 5W oils in terms of viscosity.</TD></TR></TABLE>
i didnt say it was the best i said i herd it was the best one to get
Old Feb 5, 2004 | 11:48 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by capcon83 &raquo;</TD></TR><TR><TD CLASS="quote">i didnt say it was the best i said i herd it was the best one to get </TD></TR></TABLE>
So what are you saying then?
Old Feb 5, 2004 | 11:50 AM
nsxtasy's Avatar
H-T Order of Merit
According to the owner's manual, 5W30 is the preferred viscosity at all temperatures.
&lt;ducks&gt;
Old Feb 5, 2004 | 11:51 AM
capcon83's Avatar
So what are you saying then?</TD></TR></TABLE>
if i should get 0W-30 for my next oil change. thats why i asked if anyone tryed it and if anyone recommend using 0W-30 instead of 5W-30 like i wrote in my first post
Old Feb 5, 2004 | 11:53 AM
.RJ's Avatar
.RJ
Was I unclear with what i replied with?
If you are using Mobil 1, stick with 5W-30.
Old Feb 5, 2004 | 12:31 PM
00MRSi's Avatar
Default Re: motor oil question 0W30 (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
&lt;ducks&gt;
Bingo. Stick with what the owners manual recommends..
Old Feb 5, 2004 | 12:40 PM
Bbasso's Avatar
Default Re: motor oil question 0W30 (00MRSi)
If you have a doubt about oil, then read this :
Old Feb 5, 2004 | 01:38 PM
BooWeTODD
Guest
Posts: n/a
Default Re: motor oil question 0W30 (Bbasso)
OT: for my Gsr
Since i want to save making a thread ill just ask here, does anyone know the recommended oil for a GS-R. I was told to use 10w30 since my motor has over 60k.
Old Feb 5, 2004 | 01:40 PM
Dave-ROR's Avatar
Default Re: motor oil question 0W30 (BooWeTODD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BooWeTODD &raquo;</TD></TR><TR><TD CLASS="quote">OT: for my Gsr
Since i want to save making a thread ill just ask here, does anyone know the recommended oil for a GS-R. I was told to use 10w30 since my motor has over 60k. </TD></TR></TABLE>
I have always used 10w-30 (sometimes straight 30) in my gs-r. I live in florida where the cold weight isn't as important IMO.
Old Feb 5, 2004 | 01:57 PM
jond's Avatar
Default Re: motor oil question 0W30 (Dave-ROR)
I've looked at lots of oil reports on the bobistheoilguy forum, and I've got many samples done myself.
I'm not sure what to recommend anymore. At first, I would say 0w30 is insain, but looking at the numbers people are getting, it may not be that bad.
Then again, the biggest downside of 0w30 is the addidtion of additives. Most people driving normally wont break down additives like we will reving to 8400+ and driving for miles and miles at 4,000 - 5000 rpm.
The only way to know for sure is to get oil samples using 5w30 and with 0w30. See what the difference is.
Old Feb 5, 2004 | 05:48 PM
Tweakmeister's Avatar
Default Re: motor oil question 0W30 (jond)
I tend to shy from 0w30 because of the burning issue (and as jond wrote).
5w30 is pretty much the best route (for most oils).
Old Feb 5, 2004 | 07:20 PM
sgT's Avatar
sgT
Default Re: motor oil question 0W30 (Tweakmeister)
when its warm i use 10-40 or 20-50
when its cold 5-30 regular or 5-50 synthetic
Old Feb 6, 2004 | 08:20 PM
97 TYPE-R 312's Avatar
Default Re: motor oil question 0W30 (julow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by julow &raquo;</TD></TR><TR><TD CLASS="quote">I use AMS 0w30. Great stuff. </TD></TR></TABLE>
same here! I haven't had any issues with it in terms of burning.
-Victor
Old Feb 6, 2004 | 08:29 PM
kool168's Avatar
Default Re: motor oil question 0W30 (97 TYPE-R 312)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97 TYPE-R 312 &raquo;</TD></TR><TR><TD CLASS="quote">
-Victor</TD></TR></TABLE>
in all seasons? how long you have to change oil using AMS 0W30?
Old Feb 6, 2004 | 08:34 PM
Default Re: motor oil question 0W30 (SOL-R)
the normal intervals
-Victor
Old Feb 6, 2004 | 10:44 PM
ejprimo's Avatar
out of the mobil 1 line-up id go with mobil1 10w-30 year round. mobil 1 5w-30 and 10w-30 both have a pour point of -45C so i dont doubt the 10w-30's cold weather capabilty. 10w-30 has a higher HTHS (3.17&lt;3.08) and a higher flashpoint (244&lt;224) than 5w-30. they both have an equal viscosity at operating temp. (10cst@100C). 5w-30 has a higher viscosity index (167&lt;147) than 10w-30. also note that m1 0w-30 and 5w-30 has the same viscosity at start-up, 56cst@40C.
specs: (look under typical properties)
m1 5w-30:http://www.mobil.com/USA-Engli...0.asp
m1 10w-30:http://www.mobil.com/USA-Engli...0.asp
m1 0w-30: http://www.mobil.com/USA-Engli...0.asp
Old Feb 11, 2004 | 10:22 AM
96dc2's Avatar
if i should get 0W-30 for my next oil change. thats why i asked if anyone tryed it and if anyone recommend using 0W-30 instead of 5W-30 like i wrote in my first post</TD></TR></TABLE>
Use 10w30. It doesn't get that cold here.
Old Mar 5, 2004 | 11:08 AM
sysconx's Avatar
Hey, I just put M10W30. I spoke with an engineer that tests and know about these oils. He says he uses 0W40. I don't think it is that widely available on the marked but he recomends using it and states that there are no harmful effects to this grade oil. I think somewhere in the posts someone mentioned using 20W50. I tried this oil on another car I had and blew out a seal by the oil pump. Too much pressure to work with.
Hope to get some comments. Regards, Kris
Old Mar 5, 2004 | 11:20 AM
sysconx's Avatar
Default Re: motor oil question 0W30 (sysconx)
0W-30 oil acts like 0 weight oil when cold, but maintains a 30 weight viscosity when hot. Think of it this way: when your engine is hot, there is basically no difference between 0W-30, 5W-30, and 10W-30 oil. They are all acting like 30 weight oil at this point. It's at cold startup, when almost all engine wear occurs, that the viscosity is different. The 0 weight oil will get to the engine components quicker than the 10 weight oil, but in reality cold 0 weight oil is still thicker than hot 30 weight oil. Ok?
Old Mar 5, 2004 | 11:22 AM
Pompiuses's Avatar
I'm running Castrol TWS 10W60 during summer, when I'm tracking the car a lot. In winter I use Castrol SLX 0W30 which is what Honda recommend (at least in Europe). Works great for me...
Old Mar 5, 2004 | 04:48 PM
DutchITR1689's Avatar
Default Re: motor oil question 0W30 (Pompiuses)
Castrol RS 0W-40 in the winter
Castrol RS 10W-60 in the summer
Old Mar 5, 2004 | 05:40 PM
ejprimo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pompiuses &raquo;</TD></TR><TR><TD CLASS="quote"> In winter I use Castrol SLX 0W30 which is what Honda recommend (at least in Europe). Works great for me...</TD></TR></TABLE>
thats what im using right now year round. the oil is green, huh?.
