What cams for this set up:
Old Feb 5, 2004 | 11:04 AM
MissMyHonda's Avatar
Default What cams for this set up:
Ok so the motor build up is starting this week, and I still have to decide a few things.
Right now the current plan is:
CTR Pistons .25 over
Toda Valve Springs
Eagle Rods
Re-balance Crank
BCIII Exhuast
SMS Header
Custom IM
AEM EMS
Base motor is a JDM ITR w/ USDM ITR Tranny w/ 4.785 FD...any needed fuel delivery will be taken care of as well (pump, injectors, rail, etc..)
Now what cams would you run w/ that, I don't care about power below like 6-7 and I only want to rev to like 9.5 (if the cams keep making power I'll go higher)
Also, would you suggest that I say **** it and get some bigger pistons, go 2.0L?
I don't want to go higher than like 13.0:1 Compression though, so keep that in mind.
Old Feb 5, 2004 | 11:49 AM
T S R Performance's Avatar
Default Re: What cams for this set up: (JoesTypeS)
Nice Setup. Id go with skunk 2 stage 2 cams. not as lopey as stage 3 and they are better for a street car setup. if youre going full race get stage 3. stage 2 can pull up to 10.5 i beleive. good luck and i hope i was help with some input on your motor.
Old Feb 5, 2004 | 03:10 PM
infamousR13's Avatar
Bigger pistons=yes! But not with out resleeving obviously. If you are going to put in the money and the time, you might as well go 2.0L, the torque is awesome! I would also go with a set of cams from rocket, I have heard many good things about his products, I think you can find them at rocketmotorsports.com, but I may be wrong.
Old Feb 5, 2004 | 03:34 PM
oh, PS - I live in NY and im my area we have 94 and 100 octane pump gas
Old Feb 5, 2004 | 04:34 PM
jdm_redneck's Avatar
I would also go with the skunk stage 2, or toda spec b.
Old Feb 5, 2004 | 07:35 PM
eh i just got VTEC killers so now the question is 2.0 or not
Old Feb 6, 2004 | 09:29 PM
SpeedingHatch's Avatar
Default Re: (JoesTypeS)
Bump
Cuz no matter how much money you put into your teg, H>B
BTW go 2.0
Old Feb 6, 2004 | 09:36 PM
Type-Rare#1248's Avatar
just wondering what made you pick CTR pistons over other forged pistons?
Old Feb 6, 2004 | 09:40 PM
zensoku207's Avatar
I'm a fan of JUN 3's....but some people are skeptical of the coarse idle, for street.....they got mean power gains tho.....
Old Feb 6, 2004 | 11:51 PM
AMGTortoise's Avatar
Default Re: What cams for this set up: (CivicHatchSOHC)
Just for those who have not tested both cams Skunk2 Stage 2's or Stage 3's, & guessing that they will not work CR below 12:1. The Skunk2 Stage 3's are indeed streetable with just 11.6:1 cr... they have no idle problems as they have smaller Pri. & Sec. lobes than the Stage 2's. And, here's some information for you all to share & enjoy:
Stage 2's Mid-lobes will get overlaps of 58.00 degrees. 0/0
Stage 3's Mid-lobes will get overlaps of 67.00 degrees. 0/0
Stage 2 intake with Stage 3 exhaust Mid-lobes will get overlaps of 69.00 degrees. 0/0 (Works best for all-motor)
Stage 3 intake with Stage 2 exhaust Mid-lobes will get overlaps of 56.00 degrees. 0/0 (Good for turbo)
BTW, I'm sure no one knows the specs for the Jun 3's (BTDC, ABDC, BBDC, ATDC) measured @1mm seats for the Pri, Sec & Mid neither.?!?!!? Just guessing with opinions (they are streetable too).
Old Feb 7, 2004 | 08:28 AM
Miller Time!'s Avatar
I think you would have alot of luck with The RS machine Vtec cam... they seem to work on any B series motors from 1.6 to 2.3 Ive expierimented with the cams for sometime now from daily driven street cars to race cars such as my own and have not found a cam yet that will out power the RS cams most people wouldnt believe it because RS doesnt really hype up there cams with strong marketing/advertising but you can take it from me it works for you guys wondering what cams ive tested this against to name a few "popular cams" Toda C&D Skunk 2&3 Jun3. Im trying to get my scanner to work as soon as i do that I will post the dyno sheets....
Old Feb 7, 2004 | 11:58 PM
yeah well I traded my stock ITR head for lens Killer head...now I think I'm gonna go 84mm just so I can keep higher compression with less domed pistons..
Old Feb 8, 2004 | 12:51 PM
JDM2ndGen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infamousR13 &raquo;</TD></TR><TR><TD CLASS="quote">Bigger pistons=yes! But not with out resleeving obviously. If you are going to put in the money and the time, you might as well go 2.0L, the torque is awesome! I would also go with a set of cams from rocket, I have heard many good things about his products, I think you can find them at rocketmotorsports.com, but I may be wrong.</TD></TR></TABLE>i just bought my RM head package from Kteller.com ...&lt;great customer service
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoesTypeS &raquo;</TD></TR><TR><TD CLASS="quote">oh, PS - I live in NY and im my area we have 94 and 100 octane pump gas</TD></TR></TABLE>im in new york and every sunoco around me got rid of 94 ...this made me very madd ...where do they have 100?
Old Feb 8, 2004 | 01:03 PM
Default Re: (JDM2ndGen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM2ndGen &raquo;</TD></TR><TR><TD CLASS="quote"> ...where do they have 100?</TD></TR></TABLE>
Delta Sonic
Old Feb 8, 2004 | 01:22 PM
JDM2ndGen's Avatar
Default Re: (speedinghatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedinghatch &raquo;</TD></TR><TR><TD CLASS="quote">
Delta Sonic</TD></TR></TABLE>thanks ...im goin to have to find one near me
Old Feb 8, 2004 | 05:27 PM
12secB18acivic's Avatar
Default Re: What cams for this set up: (spin2win)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spin2win &raquo;</TD></TR><TR><TD CLASS="quote">I think you would have alot of luck with The RS machine Vtec cam... they seem to work on any B series motors from 1.6 to 2.3 Ive expierimented with the cams for sometime now from daily driven street cars to race cars such as my own and have not found a cam yet that will out power the RS cams most people wouldnt believe it because RS doesnt really hype up there cams with strong marketing/advertising but you can take it from me it works for you guys wondering what cams ive tested this against to name a few "popular cams" Toda C&D Skunk 2&3 Jun3. Im trying to get my scanner to work as soon as i do that I will post the dyno sheets....</TD></TR></TABLE>
yes, dyno sheet please!
gs1gsr
17
Oct 3, 2008 02:58 AM
hybridpatient95
22
May 16, 2006 02:54 AM
0bd1_Kanobe
35
Feb 28, 2004 03:38 PM
VtecDA9
Jan 7, 2004 08:12 AM
