Wideband O2 Sensor and Datalogger for $350...Anyone Used It Before?
Old Feb 5, 2004 | 08:27 AM
LudeyKrus's Avatar
Default Wideband O2 Sensor and Datalogger for $350...Anyone Used It Before?
http://www.innovatemotorsports.com/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
LM-1: Digital Air/Fuel Ratio Meter
Tuning an engine for maximum power previously required long trial-and-error sessions on a dynamometer. With the LM-1, precise AFR measurement allows the user to correctly adjust many variables- including carburetor jetting, fuel injection, turbo fuel curves, etc.- without long and expensive dyno sessions. The meter’s digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-1’s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition.
• The instrument can sample and store the air-fuel-ratio and the other sensor data internally in operation for later analysis on a personal computer. At a sampling rate of 12 samples/second the instrument can store up to 44 minutes worth of data in non-volatile memory. The data can be downloaded to a personal computer using a standard serial port and viewed/analyzed by the included software or any standard spreadsheet program:
• The standard LM-1 includes a Bosch wide-band oxygen sensor and cable, cigarette-lighter adapter, serial cable for PC connection, 9V battery, exhaust bung and plug, CD and manual. The LM-1 ships with a Bosch sensor, however, it can also function with other wide-band sensors, including Honda/NTK and VW sensors.
• Available accessories include auxiliary input cables, alligator-clip power cable, exhaust clamp, analog output cable, and Aux. input expander. Additional accessories include a dash-mountable display and AC adapter.
The LM-1 sells for $349, including the oxygen sensor (Bosch LSU4.2), 10' sensor cable, 10' power cable, serial PC cable, and software..
Looks like an awesome product; it is a wideband O2 sensor that accepts other sensors, it self calibrates and can log data from up to 5 other sources.....all for $350. I am seriously considering buying it, but has anyone else ever used one of these?
Old Feb 5, 2004 | 08:38 AM
b18bturbo's Avatar
Default Re: Wideband O2 Sensor and Datalogger for $350...Anyone Used It Before? (LudeyKrus)
do search tons of people are using this model now with great sucess. the option for rpm pickup is kinda nice so you can datalog
Perfectionist
Oct 8, 2006 02:00 PM
b18bturbo
Mar 3, 2006 05:02 AM
michaelkota
Jan 12, 2005 10:22 PM
b00stedbyFastrax
May 16, 2004 07:04 PM
acatak
Apr 14, 2003 08:16 AM
