zc distributor
ok, im ordering my dohc zc wednesday (hmotorsonline was out...but getting more wed).....and i was looking over the parts list, and had a ?...i havent heard any different on using the distributor that came with the zc...just have to wire the two plugs correctly....now if the dizzy bumps out....and i get one for an88-89 teg like the parts list say...what am i goin to have to do about wiring?......or am i just totally wrong and need to go ahead and get a teg dizzy?
so use the zc dizzy with my teg ecu, wire it right....then just replace it with a teg one if it goes out.....right....just want to get everything correct before i jump in it
Correct me if I'm wrong but there is wiring to do. The ZC distributor will plug right in but the teg one will not. The Teg distributor uses an internal TDC sensor (or cylinder position sensor I forget). Either way you have to pop out the wires to these and wire them to the sensor which is found on the end of the exhaust cam (closest cam to the front of the car).
When all else fails with distributor wiring just go color to color. I think Dmoore's website has a pin out for that distributor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garrett »</TD></TR><TR><TD CLASS="quote">Integra 88-89 is exactly the same dizzy as the ZC DOHC 88-91 TDC is external on both</TD></TR></TABLE>
correct - 88-89 integra is same as DOHC ZC - TDC sensor is internal on both - the CPS (Cylinder Position Sensor) is external, on the end of the exhaust camshaft
Yes, there is wiring that needs to be done with the ZC, the dizzy plugs ARE NOT plug and play....go here http://www.geocities.com/civiczc/zcwire.html
El pimp chulo
Sep 26, 2006 08:02 AM
JapJunkie
Apr 1, 2004 05:14 PM
crxgurlllll
Feb 16, 2002 05:45 PM
