Toda pistons questions
Old Oct 7, 2001 | 12:49 AM
ITR111's Avatar
New User
Default Toda pistons questions
will 82mm toda pistons with 1.0mm head gasket knocks really bad??
Old Oct 7, 2001 | 12:53 AM
Stock-DC2's Avatar
New User
Default Re: Toda pistons questions (ITR111)
I think that depend on the ECU map you are running and the kind of fuel you use.
It should be OK if you get your stock ECU reprogram for it, and run 94 octane gas all day.
Old Oct 7, 2001 | 07:28 PM
AJ PwR's Avatar
If you are getting Toda 82mm pistons , why you want 1mm head gasket? I think you should run a 0.6mm (same as stock) gasket. You can run 12.5 CR without probelms with proper tuning.
Old Oct 7, 2001 | 07:29 PM
FSTASNTZ's Avatar
Yes, I agree, I am running 12.5:1 and stock head gasket. No problems with knock.
Jason
Old Oct 7, 2001 | 07:52 PM
Stock-DC2's Avatar
New User
Default Re: Toda pistons questions (AJ PwR)
That is true, but with one bad tank of gas, bye bye engine!!
It all depend if you want all out power or to be on the safe side a little bit.
Old Oct 7, 2001 | 08:03 PM
FSTASNTZ's Avatar
Safe? Just watch the timing...
Jason
jansenrw
Apr 9, 2003 05:13 AM
Toda
Feb 26, 2003 03:17 PM
TypeR0149
Feb 24, 2002 07:12 AM
