Engine Horsepower Power Low
I got a b16A2 with lots of bolt on mods. With all fuel mods(rail, pump, filter, regulator), CAI, 4-into-1 header, tester pipe, 2 1/1" exhaust, pulleys, Intake manifold, Msd 6AL, MSD coil, MSD plugs, V-tec controller, dyno tuned, but the power is still very low. My numbers at the wheel are 142.8 hp and like 102 tq. Dont unterstand why the horse power is low? Been told that it is the intake manifold. Also been told it shoud be making more like 155hp-160hp.
Some One please help!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ORcivicsi »</TD></TR><TR><TD CLASS="quote">Also the compression is like 205psi in 3 cylinders, and 190psi in the last.
Just cant figure it out.</TD></TR></TABLE>Maybe cuz you got something wrong w/ one of the cylinder. Get a leakdown test done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3rdGteg »</TD></TR><TR><TD CLASS="quote">Maybe cuz you got something wrong w/ one of the cylinder. Get a leakdown test done. </TD></TR></TABLE>
Hahaha...Here's a question...in those motors, what is likely to be causing the screwy compression in his cylinder? Valve seals? Blown rings/ringlandings? Huh? Just curious because my brother is about to buy one of those motors...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tomservo »</TD></TR><TR><TD CLASS="quote">
Hahaha...Here's a question...in those motors, what is likely to be causing the screwy compression in his cylinder? Valve seals? Blown rings/ringlandings? Huh? Just curious because my brother is about to buy one of those motors...</TD></TR></TABLE>It can be any one of those you implied; that's why he should get a leakdown done to see which one it is.
compression is fine, think you may have the wrong mods for your setup, to much TB and manifold, but no cams for the additional air, if you are running a big plenum type manifold you dont need it untill high rpms, take your fuel pressure back down to stock and run it again with the stock TB, you gained Volume but lost air velocity. just my opinions without seeing the car.
_Not_So_Nice_Guy
Jul 24, 2003 02:36 PM
