ZC block with LS head???
Old Feb 4, 2004 | 09:46 PM
BlckBeautyVTEC's Avatar
Default ZC block with LS head???
out car shoppin and i came across a 91 civic Si and when i popped the hood i noticed an LS head on it but when i read the engine code from the block it read ZC the stock Si motor for that year i didnt think youc could put a 1.8l head on the orginal i think 1.5 or 1.6 l block can anyones explain this to me?
Old Feb 4, 2004 | 09:52 PM
Bob_Digi's Avatar
the ZC isnt the stock motor for that car also ZC's look like ls motors so are u sure about that and also how could u tell that it was an ls head?
GSteg's Avatar
first of, how do you know it's really an LS head?
Old Feb 4, 2004 | 09:55 PM
Default Re: (GSteg)
looks like and LS head to me has the two cam gears on the side and not one lol has the valve cover so i assume i didnt look under neath the cover but it did have to cam gears spinnin
Old Feb 4, 2004 | 10:00 PM
Bob_Digi's Avatar
Default Re: (GSteg)
o boy
Old Feb 4, 2004 | 10:06 PM
frostt3ch's Avatar
zc's come in dohc also.
Old Feb 4, 2004 | 10:08 PM
Default Re: (frostt3ch)
so would it just be a DOHC zc
Old Feb 4, 2004 | 10:16 PM
Trixiem's Avatar
Default Re: (BlckBeautyVTEC)
yup the only DOHC d series
-kenny
Old Feb 5, 2004 | 09:24 AM
Default Re: (Trixiem)
are all zc DOHC or do they also make SOHC
Old Feb 5, 2004 | 10:02 AM
DumpedSi's Avatar
single cam too
Old Feb 5, 2004 | 10:28 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: (Slammed Si)
you learn something new everyday.
Old Feb 5, 2004 | 04:07 PM
Default Re: (vtecb20coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb20coupe &raquo;</TD></TR><TR><TD CLASS="quote">you learn something new everyday. </TD></TR></TABLE> Yes i do
Old Feb 5, 2004 | 04:10 PM
what cars did the ZC come in on both USDM cars and JDM cars
Old Feb 5, 2004 | 04:11 PM
Targa250R's Avatar
be professional
Default Re: ZC block with LS head??? (BlckBeautyVTEC)
All 1.6L D-series engines from Japan are stamped "ZC." There are DOHC non-VTEC, SOHC non-VTEC, and SOHC VTEC ZCs.
The engine you saw was a DOHC ZC, which has a valve cover that looks somewhat similar to a B18A valve cover (there are a few differences though). You cannot use a B-series head on a D-series block, they are not interchangeable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlckBeautyVTEC &raquo;</TD></TR><TR><TD CLASS="quote">what cars did the ZC come in on both USDM cars and JDM cars</TD></TR></TABLE>
ZCs came in many, many different cars in Japan, including 3rd, 4th, and 5th-gen Civics, 1st, 2nd, and 3rd-gen CRXes, and 1st, 2nd, and 3rd-gen Integras. Some were dual-carbureted and some were multi-port fuel-injected. As I mentioned before, there are DOHC non-VTEC, SOHC non-VTEC, and SOHC VTEC ZCs.
No engine sold in the United States was ever stamped "ZC." Our 1.6L D-series engines were all stamped as "D16 _ _."
Check here for more ZC info.
Modified by Targa250R at 8:21 PM 2/5/2004
Old Feb 5, 2004 | 04:31 PM
Default Re: ZC block with LS head??? (Targa250R)
Ok i think i understand now ZC came invarious "forms" this calrifies everything now thanks for all the info everyone put thanks.
Old Feb 5, 2004 | 04:33 PM
frostt3ch's Avatar
they come both in single and dual. its similar to a 87-89 intgra motor but with 130 hp. the dohc pulls pretty good i had one in my crx.
Old Jun 17, 2004 | 11:18 AM
Slow_Em1's Avatar
Default Re: (bob evans)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bob evans &raquo;</TD></TR><TR><TD CLASS="quote">o boy</TD></TR></TABLE>
Old Jun 17, 2004 | 11:41 AM
POE's Avatar
POE
Default Re: (Slow_Em1)
someone needs to edumacate this bOY!
Old Jun 17, 2004 | 11:51 AM
egOt's Avatar
Default Re: (Vtecin94dx)
Targa just did
johnpowellcrx
Oct 26, 2004 08:45 AM
90SICRX
26
May 14, 2004 06:52 AM
Mug3nman
Nov 20, 2003 09:30 PM
onePOINTsix
Jun 28, 2003 04:24 PM
crxzc
Jun 17, 2002 03:38 PM
