00-01 ITR rims on RSX ?
I was thinking of switching to a base brake setup and using a set of itr for the track to run a smaller slick but i also dont want poor brake performance maybe if i can some how use the mugen itr brake setup for the dc2 then i would do it.Car would accelerat like crazy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoSoJeff »</TD></TR><TR><TD CLASS="quote">will the 16inch ITR wheels fit?</TD></TR></TABLE>
Yes , they would fit , but not worth it IMO ....
those OEM JDM 16's on the JDM DC2R weigh around 16+ pounds ....
You be alot better of, just spending the money on some light weight 16x7 or 16x7.5's .....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackdc5 »</TD></TR><TR><TD CLASS="quote">
The JDM ITR 16x6.5" (or 7" I'm not sure) will fit. I've seen it on a white RSX (now totalled
....) I think the offset is +55mm similar to S2000 front wheels (pre '04) that means they have +10 mm more offset than stock rsx wheels...they will be tucking more. It's not good for performance aspects anyway. More for looks and I'd definitely rock them if I could get it cheap (too bad JDM is expensive). IMO Gunmetal would look perfect on my blackdc5...im getting tired of my flat black rsx wheels.
RSX wheels weigh 16-16.5lbs. Unless the JDM ITR wheels are a LOT more than 16 lbs, it's not a big deal.</TD></TR></TABLE>
They are 16x7 ....not sure about the off-set
....) I think the offset is +55mm similar to S2000 front wheels (pre '04) that means they have +10 mm more offset than stock rsx wheels...they will be tucking more. It's not good for performance aspects anyway. More for looks and I'd definitely rock them if I could get it cheap (too bad JDM is expensive). IMO Gunmetal would look perfect on my blackdc5...im getting tired of my flat black rsx wheels.RSX wheels weigh 16-16.5lbs. Unless the JDM ITR wheels are a LOT more than 16 lbs, it's not a big deal.</TD></TR></TABLE>
rsxturbo
Mar 14, 2002 08:41 PM
type_S
Nov 4, 2001 02:31 PM
