loose door, tigtening door hinges?
Old Feb 4, 2004 | 04:34 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default loose door, tigtening door hinges?
My driver side door, the one that was replaced last March, seems fairly loose. If the car is on even the slightest uphill incline or slope down to the right (like the right side of a street), the weight of the door will make the door close by itself. The passenger side door is tighter and doesn't have this problem. Is there any way to tighten the driver side door hinges?
Old Feb 5, 2004 | 04:04 AM
JimBlake's Avatar
Default Re: loose door, tigtening door hinges? (PatrickGSR94)
Isn't that what the door checker is supposed to do? That's not exactly part of the hinges...
It's #16.
Old Feb 6, 2004 | 10:25 PM
stumpyf4's Avatar
Default Re: loose door, tigtening door hinges? (JimBlake)
Door checker worn out... replace and you're good to go.
Old Feb 6, 2004 | 11:07 PM
Understeer's Avatar
Default Re: loose door, tigtening door hinges? (stumpyf4)
While we are on the topic of doors, my drivers side door is slightly crooked and doesn't align properly.
I need to move the door up a couple millimeters, what do I need to take off to do this?
Old Feb 9, 2004 | 10:46 PM
Uneekpinoysk8er's Avatar
whats the part number of 9 and6 int hat picture cause i need it for my dirver side door.
Old Feb 10, 2004 | 03:38 AM
JimBlake's Avatar
Default Re: loose door, tigtening door hinges? (Uneekpinoysk8er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Uneekpinoysk8er &raquo;</TD></TR><TR><TD CLASS="quote">whats the part number...</TD></TR></TABLE>Check out http://www.acuraautomotiveparts.org & put in your own year & version...
They don't use real Honda part #s, so if you buy from someone else just print the picture & walk up to the parts counter & point at it...
suhteevin
Jan 6, 2009 09:04 PM
confusatron
Mar 20, 2006 09:41 PM
98itR484
May 22, 2002 09:20 PM
