need help idling too high
I have a 91 CRX HF, it has a '96 dx motor in it, but has the OBD0 manifolds, sensors etc... I replaced the TPS, but it still idles high. Does anyone have any clue what could be the problem? Thanks for your help in advance.
Does anyone on here know how to reset the tps and where is the screw to adjust the idle located, i tried looking at the throttle body and couldn't find it.
my IACV started to get loose on my b16 and it started to idle high. Then all of the sudden it reved up to rev limiter on its own. Just a though. Do a search I am sure you will find alot.
later
Matt
later
Matt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6-DC2 »</TD></TR><TR><TD CLASS="quote">Does anyone on here know how to reset the tps and where is the screw to adjust the idle located, i tried looking at the throttle body and couldn't find it.</TD></TR></TABLE>
If the HF is the same as the Si then the adjustment screw will be on the top of the TB on the firewall side.
Thanks so far to everyone for your help, when the weather clears up and we have a chance to work on it outside, i will check them all. I f anyone else has anymore suggestions please list them. Thanks.
nolan, the idle screw for my prelude was located actually under the throttal body it had 2 screws on it and that released a cap and inside was a screw just tighten that up and it fixed my idle just fine.
cirionrc
Apr 27, 2002 10:47 AM
