clutch problem or master/slave cylinder ?
Old Feb 4, 2004 | 02:59 PM
4door-r's Avatar
Default clutch problem or master/slave cylinder ?
the tranny wont go into gear from nuetral but if i start it with it in gear the car will shift but at 75%. when i start it with it in gear w/ the clutch in the tranny is still engaged,i checked the slave cylinder it moves a half inch when clutch pedal is pressed and there is on fluid leak inside or out.i dont want to start taking it appart before i know whats wrong so i can order what in need.
lo0nY
Feb 26, 2006 03:58 PM
rollercosta123
Jan 2, 2006 12:14 AM
johnqt3
Oct 7, 2005 11:05 AM
