pic request: JDM HID ITR headlights cutoff beam pattern
Old Feb 4, 2004 | 02:14 PM
MikeyDB7's Avatar
Default pic request: JDM HID ITR headlights cutoff beam pattern
Hey I would like to request pictures of JDM HID ITR headlights and their cut off beam pattern...
thanks for the help guys..
still deciding whether to upgrade!
Old Feb 4, 2004 | 03:50 PM
MikeyDB7's Avatar
Default Re: pic request: JDM HID ITR headlights cutoff beam pattern (MikeyDB7)
bump..anyone?
Old Feb 4, 2004 | 03:56 PM
canuck-mx6's Avatar
compared to my HID kit in USDM ITR headlights
Here is a pic that I deliberately underexposed so you can see the blue line at the cut off. This is what gives you that flicker effect that you see
Modified by canuck-mx6 at 5:06 PM 2/4/2004
Old Feb 4, 2004 | 04:03 PM
MikeyDB7's Avatar
Default Re: pic request: JDM HID ITR headlights cutoff beam pattern (canuck-mx6)
nice..thanks!
Old Feb 4, 2004 | 04:55 PM
:jdmshmaydm:'s Avatar
Awesome pics. Did you purposely wire up your sidemarkers to stay on all the time?
Old Feb 4, 2004 | 05:06 PM
T I F O S I's Avatar
Default Re: pic request: JDM HID ITR headlights cutoff beam pattern (Gatecrasher20AF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gatecrasher20AF &raquo;</TD></TR><TR><TD CLASS="quote">Awesome pics. Did you purposely wire up your sidemarkers to stay on all the time?</TD></TR></TABLE>
no thats how mine are too, i think they are wired that way stock... but i may be wrong, i didnt install mine
Old Feb 4, 2004 | 06:35 PM
jdmspoonitr's Avatar
Default Re: pic request: JDM HID ITR headlights cutoff beam pattern (goldeknug)
The sidemarkers are supposed to light up when the corners light up. THe corners are not supposed to be illuminated 24/7 either. My old jdm front was wired so that the corners were always illuminated, but in Japan they only light up when you hit the signals or hazards. That is the same for the sidemarkers too.
The 24/7 illumination occurs when a shop doesn't know what they are doing and they use your existing usdm wiring and just hook it up to the jdm front.
Old Feb 5, 2004 | 01:56 AM
canuck-mx6's Avatar
Default Re: pic request: JDM HID ITR headlights cutoff beam pattern (jdmspoonitr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspoonitr &raquo;</TD></TR><TR><TD CLASS="quote">The sidemarkers are supposed to light up when the corners light up. THe corners are not supposed to be illuminated 24/7 either. My old jdm front was wired so that the corners were always illuminated, but in Japan they only light up when you hit the signals or hazards. That is the same for the sidemarkers too.
The 24/7 illumination occurs when a shop doesn't know what they are doing and they use your existing usdm wiring and just hook it up to the jdm front.</TD></TR></TABLE>
Actually I wanted it wired that way. I know the "JDM" way of doing it, but I wanted them to function as a "marker" and also as a turn signal. When my front turn signals blink, the side markers go off, so you get an alternating pattern.
I wanted the side markers to stay on all the time, as there are no lights on the side of the car anymore, (the USDM bumper lenses could be seen from the side). Without the sidemarkers being on, you can't see any lights on the side of the car, since you can't see the headlights fron the side, and I thought that it was a little "safer" doing it this way.
sikciv666
Northeast (Sales)
Mar 24, 2013 11:26 AM
DA 4 Lyfe
Sep 18, 2007 07:20 PM
hmongyaj87
Jun 4, 2007 01:01 AM
migs
Feb 6, 2003 03:34 PM
