Help with vtec
Old Feb 4, 2004 | 02:13 PM
pr3crx's Avatar
Default Help with vtec
i've got a '90 crx w/ a b16. my vtec isn't working. i have already checked all the wiring and i'm confident that the solenoid is in working order. my ecu isn't showing a code. what do i do now?
Old Feb 4, 2004 | 02:45 PM
D16a6 2NR's Avatar
Default Re: Help with vtec (pr3crx)
do u have a knock sensor hooked up or not
Old Feb 4, 2004 | 03:07 PM
Patch's Avatar
Default Re: Help with vtec (D16a6 2NR)
A knock sensor isnt needed to engage vtec.
You need these things for vtec to engage on a stock PR3:
VSS signal
TPS signal
coolant temperature sensor
RPM
vtec pressure switch
vtec solenoid
Old Feb 4, 2004 | 05:03 PM
HamiltonRex's Avatar
Default Re: Help with vtec (1993sir)
What code are you throwing?
Old Feb 4, 2004 | 07:56 PM
Patch's Avatar
Default Re: Help with vtec (Patch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patch &raquo;</TD></TR><TR><TD CLASS="quote"> A knock sensor isnt needed to engage vtec. </TD></TR></TABLE>
Old Feb 4, 2004 | 08:36 PM
krazie1's Avatar
BANNED
as he said he ain't getting a code
i would tell u to check ur wiring from the pressure switch
i just found out this was my problem
i had them mixed up
just my opinion
Old Feb 5, 2004 | 09:59 AM
pr3crx's Avatar
Default Re: Help with vtec (krazie1)
Thanx guys.
Old Feb 5, 2004 | 10:04 AM
ironchef25's Avatar
what about vtec fluid?????
ntoxicatedtigah
Jun 24, 2009 02:56 PM
user 72830283
Oct 16, 2005 08:24 AM
B18cHatch06
Sep 30, 2005 11:39 PM
dryhopsux13
Apr 8, 2005 06:02 AM
Raunch
Nov 8, 2003 10:05 PM
