Need help QUICK
http://www.imagestation.com/pi...b.jpg
[IMG][/IMG]
well i dont know if its supposed to look like that or not...idk if its cuz i didnt run it any b4 i took the valve cover off or not so can someone please help me out here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MY_EL_1 »</TD></TR><TR><TD CLASS="quote">
there ya go</TD></TR></TABLE>
wow...
so, how long do you usually go before oil changes? 30000 miles?
wow...
we just changed the oil like 30-50 miles ago......and its not a joke...we have only done one oil change to it since we got it and ive only put like 300 miles on it. Its like all the oil dryed up or something
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris y0! »</TD></TR><TR><TD CLASS="quote">
wow...
so, how long do you usually go before oil changes? 30000 miles?</TD></TR></TABLE>
lol, no 33,333
wow...
lol, no 33,333
Guest
Posts: n/a
78 posts and a member for 4 months and you have never taken your valve cover off before?!?!!?!!? Check this site out instead -----> http://www.clubsi.com
ive used to come to this site b4 i ever had a honda or really wanted one. and i got it around xmas time and havent really bothered takin it off untill now cuz the valve cover needs painted and then i run into this ****...only 15
ok.. yoshi said this a while back, don't know if it works, as i haven't tried it...
he said that you could run about 3 quarts of automatic transmission fluid in there for about 20 minutes.. the detergents in it would clean out all that gunk.. be sure to change the oil filter when you put the auto fluid in, and when you put regular oil in there.
looks like you have some sludge in there
damn. maybe you could take a rag and try to whip as much of it out as you can that way when you try running that stuff thru there to clean it up there wont be so much to get rid of.
I would be scared that stuff is clogging up an oil leak somewhere.
I have used kerosene, diesel, and seafoam to clean stuff like that. It won't get it all the way clean, but it will get quite a bit of it.
well
my dad said that he has flushed motors b4 and it just messed the motor up most of the time...he dont kno to much about hondas tho, but he said with all the stuff that is caked up in there, the stuff you guys cant see to good will probably just clog the motor cuz its so much. He said that it would be better to take it to a shop and let them take the head apart and clean/rebuild it or w.e they gotta do to get it out of there. But i can get the same motor with a shaved head for 400 dollars and it would probably just be twice as easy to buy the motor with way less miles on it and runs good and not all caked up inside like mine then what it would be to pay for it to be cleaned and rebuilt.....but thanks everyone for the help, and my dad said that the people that had it b4 only changed the oil like 3 or 4 times since they bought it and its only had one owner other then the dealer ship
Yeah, don't try to "flush" all that crud. At the very least take the head apart and clean it; or like you said, get a different motor for a few hundred dollars. Beauty of the d-series...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diearzte2 »</TD></TR><TR><TD CLASS="quote">78 posts and a member for 4 months and you have never taken your valve cover off before?!?!!?!!? Check this site out instead -----> http://www.clubsi.com</TD></TR></TABLE>
wtf are you talkin bout....ive never taken off one of my valve covers...theres no need to if the ***** runnin fine and you know the cars history
dont be so gay
dont be so gay
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AmginE »</TD></TR><TR><TD CLASS="quote">ok.. yoshi said this a while back, don't know if it works, as i haven't tried it...
he said that you could run about 3 quarts of automatic transmission fluid in there for about 20 minutes.. the detergents in it would clean out all that gunk.. be sure to change the oil filter when you put the auto fluid in, and when you put regular oil in there.</TD></TR></TABLE> do an copmplete oil change after that then let it run for 20 minutes again them do one mor oil change .. this is so you make sure all the tranny fluid is out.. DONT buy any engine flush ****.. it eats through seal n the motor!!!
use kerosene to flush out the slugde, but i will be very careful though. i would try to flush out the slugde first to see how much you can it out. before you go out and buy you another motor. imo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua »</TD></TR><TR><TD CLASS="quote">use kerosene to flush out the slugde, but i will be very careful though. i would try to flush out the slugde first to see how much you can it out. before you go out and buy you another motor. imo</TD></TR></TABLE>
thats what they put in that engine flush shigt... it eats through your seals and shortens the life on the motor..
