Clicking Sound When Accelerating Quickly
Old Feb 4, 2004 | 10:58 AM
msmithgsr2131's Avatar
Default Clicking Sound When Accelerating Quickly
I just got my car back from the shop, they installed clutch kit, timing belt, water pump. I noticed a clicking sound (sounds like its coming from the engine) but only when I accelerate quickly and tach reaches around 4500. Anybody know what this might be??? The other posts I found didn't really help me out.
Old Feb 4, 2004 | 11:03 AM
4U2NV's Avatar
Default Re: Clicking Sound When Accelerating Quickly (msmithgsr2131)
Check your axle boots and see if they are leaking anywhere... See if there's grease all inside your wheels... If yes, it's probably your boots need replaced, this happened before on my old Accord...
If no, then check your motor mounts... See if ne of them are cracked and possibly torquing when the motor is given throttle...
Old Feb 4, 2004 | 05:51 PM
anyone? i searched and no one really had this exact same problem...it only happens when i accelerate real fast...like slam it...and only around 4000+ rpm
Old Feb 4, 2004 | 06:00 PM
1158's Avatar
Use some grease on the hamster wheel. Seriously what 4U2NV suggested sounds reasonable. Does it only do it when you accelerate or does it also do it when you turn? Maybe CV joints are shot.
Old Feb 4, 2004 | 06:49 PM
Default Re: Clicking Sound When Accelerating Quickly (Prof Kaos)
definetly doesnt happen when i turn...only when i really get on it (not slow acceleration)...checked, no grease on wheel...i listened to the sound again and it is more like a rattling sound
Old Feb 4, 2004 | 06:57 PM
1158's Avatar
Could it be a heat shield?
Old Feb 4, 2004 | 08:33 PM
how would i got about checking if thats the problem?
Old Feb 4, 2004 | 08:39 PM
1158's Avatar
Crawl under the car and try looking for any place the heat shield may be loose. Try reving while in neutral to see if it still makes the noise. My heat shield started rattling...pissed me off big time. I know you said it is a clicking sound, but mine started out like that and steadily got worse.
Old Feb 5, 2004 | 04:11 AM
thanks ill check it out
Old Feb 9, 2004 | 07:13 AM
okay i checked stuff out and im pretty sure its not the heat shield...anymore ideas???
Old Feb 9, 2004 | 09:19 AM
94geeser's Avatar
Exhaust leak
mouab18c1
Apr 28, 2010 11:09 PM
aladdin
Sep 7, 2007 02:31 PM
extensioncordy
Nov 22, 2006 12:23 PM
f22 lx
Aug 11, 2006 11:25 AM
redacura
Apr 23, 2004 05:24 PM
