finished putting in 11:5:1 piston in.
Old Feb 4, 2004 | 10:48 AM
luckypon7's Avatar
Default finished putting in 11:5:1 piston in.
i have a b18c1 just finished putting 11:5:1 .25 overbore piston in everything else is stock.i notice my vtec kicks in at 6k rpm is that normal? i know stock b18c1 kicks in at around 45k rpm.
Old Feb 4, 2004 | 10:51 AM
Project92Hatch's Avatar
Default Re: finished putting in 11:5:1 piston in. (luckypon7)
All you did was put in pistons and your vtec raised? You sure you didnt get a chipped ecu? Because you cant just put in pistons and not change anything else and have your vtec kick higher.
Old Feb 4, 2004 | 11:17 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: finished putting in 11:5:1 piston in. (Project92Hatch)
sure your tach wasn't off before? factory ones are slightly off.
Old Feb 4, 2004 | 11:50 AM
luckypon7's Avatar
Default Re: finished putting in 11:5:1 piston in. (vtecb20coupe)
my techmeter is working fine, last time i checked on stock motor it kicked in at 45k rpm.. well i left of some info..the guy i bought the block from said the block had been blue printed and balanced.. but the head is completely stock.. so what you think it is? can i use vafc to change it to kick in at 45k rpm? cause 6k rpm is to long to wait...
Old Feb 4, 2004 | 11:52 AM
WAFFLES's Avatar
something is wrong if it's "kicking" in at 6....
Old Feb 4, 2004 | 12:02 PM
luckypon7's Avatar
Default Re: finished putting in 11:5:1 piston in. (WAFFLES)
could it be that i was given somother cams instead a GSR cams?
Old Feb 4, 2004 | 03:41 PM
Cams dont effect where your vtec will kick. The only thing that can change when your vtec will kick is you ecu.
Old Feb 4, 2004 | 03:43 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Are you still running 2 stage GSR factory intake?
Old Feb 4, 2004 | 03:47 PM
WAFFLES's Avatar
Default Re: (v-attack)
could be an oil pressure problem. any oil leaks?
Old Feb 4, 2004 | 03:49 PM
Chemicalviper's Avatar
Default Re: (WAFFLES)
6k ? sounds like secondaries of GSR manifold ....
Old Feb 4, 2004 | 04:45 PM
Default Re: (Chemicalviper)
Yea well are you sure you had your butterflies hooked up before? Beauce maybe there hooked up now since you can here them at 6k. Where before they werent hooked up and you could only hear vtec kick at 4500. Try listening at 4500 and see if you can hear vtec kick still.
Old Feb 4, 2004 | 05:16 PM
The Internet Tough Guy's Avatar
Default Re: (Project92Hatch)
i'd put fifty bucks on an oil pressure problem
Old Feb 4, 2004 | 05:41 PM
Default Re: (jwn7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 &raquo;</TD></TR><TR><TD CLASS="quote">i'd put fifty bucks on an oil pressure problem </TD></TR></TABLE>
If it was oil pressure problem - check oil for one, check plugs on vtec solenoid - vacuum lines on IM - low oil will fuckaruond with vtec - mostly not making it activate properly.
Old Feb 5, 2004 | 05:30 AM
luckypon7's Avatar
oil is good no leaks, every thing is stock besides the block and injectors. you think it could be the injectors? some one mention that to me. i am currently running rc 440cc, i know over kill, but it was from when i had turbo. trying to find rc 310 or 270cc for good price to replace them. thanks for your guys input..
Old Feb 5, 2004 | 08:10 AM
WAFFLES's Avatar
Default Re: (luckypon7)
vtec runs off of rpm, speed, oil pressure, and temperature. Injectors would have nothing to do with when the crossover occurs.
Are you sure its not your secondaries opening up. They are much more audible at 5700 than the vtec crossover.
Old Feb 5, 2004 | 08:57 AM
ChrisTApher05's Avatar
man your one dumb mother ****** learn something from a person who knows cars little boy
Old Feb 5, 2004 | 09:14 AM
WAFFLES's Avatar
Default Re: (IntegraSTracer44)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraSTracer44 &raquo;</TD></TR><TR><TD CLASS="quote">man your one dumb mother ****** learn something from a person who knows cars little boy
damn...who are you talking to?
Old Feb 5, 2004 | 09:36 AM
luckypon7's Avatar
why you got to say **** like this, people are here to give there opinion of what the cause might be. i'm here to ask questions and learn thats why there is honda-tech. we all didn't know **** once before and you don't know if don't ask... if you know what happen and have skills with cars( hondas,acura) share if not don't say **** like this..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES &raquo;</TD></TR><TR><TD CLASS="quote">
Are you sure its not your secondaries opening up. They are much more audible at 5700 than the vtec crossover.</TD></TR></TABLE>
what is the secondary? when stock i only here it kick in once.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">Yea well are you sure you had your butterflies hooked up before? </TD></TR></TABLE>
what butterflies are you talking about?
Old Feb 5, 2004 | 09:46 AM
HulkSmash's Avatar
DICK
Old Feb 5, 2004 | 09:49 AM
WAFFLES's Avatar
Default Re: (HulkSmash)
A butterfly or "secondary" is located in the middle of the gsr intake manifold. They are opened up at 5700rpm. They are much more audible than vtec at 4400rpm. You really cant hear vtec unless you are really listening for it.
Old Feb 5, 2004 | 11:25 AM
luckypon7's Avatar
is it like a electircal plug or vaccum plug? under side of the mani right?
Old Feb 5, 2004 | 04:59 PM
v-attack's Avatar
There is a modulator on the drivers side of the intake with a vacuum line connected to it.
Old Feb 5, 2004 | 06:48 PM
AllMotr's Avatar
With the higher comp. ur vtec is probably still kicking in at 4500 but not noticeable till 6000rpm.
Old Feb 5, 2004 | 06:54 PM
Wouldnt be oil pressure because his vtec wouldnt kick at all. When you oil pressure is low and it doesnt kick when it supposed to it wont kick at all. I think it might even go into safe mode. Evertime a friends car vtec didnt kick it was low on oil but never kicked at a later time. I think your vtec is kicking but your hearing your secondaries kick and mistaking it as vtec.
Old Feb 5, 2004 | 07:29 PM
HONDABROMANDUDE's Avatar
This isn't completely true, On my old engine if I nailed it around a corner and the oil was a little low VTEC would come on late, whenever enough oil pressure was built.
