Heater isnt working but everythign checks out...
Old Feb 4, 2004 | 10:07 AM
Sleepin Crx's Avatar
Default Heater isnt working but everythign checks out...
hey guys, my heater hasnt been working for a very long time and its winter here in canada and its getting %$$%$ cold now, im trying 2 get the heater working
heater core is fine
blower is fine
thermo is fine
the heat **** in my climate control is sadly broken so i manually moved the valve thinggy inside the bay to hot, i grabbed the hose on it and it immendiatly got hot, ok thats good
still no heat
when i changed my timing belt a few days ago i blew air into that hose with my mouth since it was disconnected and bamm, air went through easily, no resistance, heater core isnt clogged or anything
it isnt leaking and still no heat
im out of ideas, can any1 help>
Old Feb 4, 2004 | 10:24 AM
Default Re: Heater isnt working but everythign checks out... (Sleepin Crx)
any?
Old Feb 4, 2004 | 10:47 AM
civicracer1993's Avatar
i had the same prob.. there is two cables attached to the **** you turn to hot or cold. reach down on the passenger side under the center console and u will see them they open and close another valve inside the car.. mess with them both.. when u open that valve the heat will come in.. just follow the metal cables off the temp **** if u need to find where they go..
Old Feb 4, 2004 | 10:49 AM
Default Re: Heater isnt working but everythign checks out... (civicracer1993)
sounds like a plan, i'll try that out in abit
Old Feb 4, 2004 | 11:18 AM
SOHC Gord's Avatar
make sure your cooling system is bleed good
Old Feb 4, 2004 | 11:35 AM
dc2_and_ef's Avatar
Default Re: Heater isnt working but everythign checks out... (SOHC Gord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC Gord &raquo;</TD></TR><TR><TD CLASS="quote"> had the same prob.. there is two cables attached to the **** you turn to hot or cold. reach down on the passenger side under the center console and u will see them they open and close another valve inside the car.. mess with them both.. when u open that valve the heat will come in.. just follow the metal cables off the temp **** if u need to find where they go..
I did this, it sucks because you can control it on the fly, but i had the same problem
Fo-Do Fanatic
Nov 21, 2009 09:42 AM
TaDLaD
Oct 1, 2009 11:31 AM
philkehn
13
Sep 21, 2006 12:02 PM
vc
Oct 7, 2005 12:49 PM
Conechaser
Oct 2, 2001 01:00 PM
