95 ex motor in a crx
you should of put this in the crx forum you probably would have got a better response. It should pretty much plug and play as long as you use the crx's intake and exhaust manfolds and sensors. Then all you should have to do is make a vtec activator. (Ghetto but it works) - NOTE: i have not done this exact swap, but have done simalar.
you are going to have a pain in the *** time Im trying to put a 2k HX engine into an 89 civic (same chassis) and Its been a bastard and theres still a few obstacles I need to figure out how to get around.
The 95 will be easier than the 2000 beacue the 2000 IS obd 2, the 95 is obd1, the the 4G civics are still obd 0, so there will be wireing isues... Manifolds shouldnt be a problem, Iw ill bolt right in, But If you go obd1 you will need the d16z6 dizzy, If you stay non obd I think you have to modify the stock si dizzy to fit the ex head...
GTEC913
Nov 29, 2006 11:20 PM
1988project
Jul 28, 2005 06:18 PM
