DC JDM 4-1 VS. JDM 4-1
If you had to choose between the two which would you choose and why?? I'm looking at gains all across the powerband not just peak hp.
Also, don't tell me to search, I've quite familiar w/ the two setups, just looking for the opinions of others.
had the OEM JDM 4-1 on my 1st R.. thought it was great.. had the skidplate and upper heat shield to hide it..
i bought the DC JDM 4-1 for my current R.. same or slightly better gains for less money. A lot less.... Skidplate can be fabbed from Home Depot parts and I didn't care about the upper heatshield since this is basically going to be a racecar anyhow..
The DC is the better deal, it flows better and is cheaper. The only downside, as mentioned above, is the horrible ground clearance. I'm using the DC and ground clearance hasn't been an issue, so I'd say go for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">The DC is the better deal, it flows better and is cheaper. The only downside, as mentioned above, is the horrible ground clearance. I'm using the DC and ground clearance hasn't been an issue, so I'd say go for it.</TD></TR></TABLE>
same here.. if you're that worried, fab a skidplate..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar »</TD></TR><TR><TD CLASS="quote">same here.. if you're that worried, fab a skidplate..</TD></TR></TABLE>
I'm more worried about the head, bolts and various other parts that's connected to the header than the header itself. You bottom out and all that force is being transmitted "somewhere".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thk »</TD></TR><TR><TD CLASS="quote">
you driving over speedbumps at 45mph?
</TD></TR></TABLE>you driving over speedbumps at 45mph?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar »</TD></TR><TR><TD CLASS="quote">you driving over speedbumps at 45mph?
It's called New York City.
That and I'd rather be on the safe side in case I go off roading at a track near you.
</TD></TR></TABLE>It's called New York City.
I run the DC.. I noticed midrange gains as well as uptop.
However, I remember seeing the 2 dyno'd against each other and they were nearly Identical in gains. But, this was mated to the stock exhaust..
The DC has a 2.5" collector, so mated to a 2.5" exhaust you should see better gains.
The DC is also cheaper, and weighs much much less than the OEM manifold. That alone is worth the price..
I'm running stock suspension and won't be switching anytime soon. Does the DC have shitty clearance even w/ OEM suspension?
Also, I would most likely keep the stock cat-back, still worth it?
Thanks to everyone who has replied already
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thk »</TD></TR><TR><TD CLASS="quote">Heck, I've had problems with a Spoon header and stock suspension.
But I'm a bad pothole dodger.</TD></TR></TABLE>
I feel you there, I had one unlucky light scuff. I mean just a scratch, not dented, thank god
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGoose18 »</TD></TR><TR><TD CLASS="quote">I'm running stock suspension and won't be switching anytime soon. Does the DC have shitty clearance even w/ OEM suspension?
My car is lowered on GC coilovers w/the JDM DC.. Clearance isn't great, but I haven't scraped *yet*.. I can get some pics of clearance for ya later.
EDIT: here are the pics.
I tried to get some zoomed out pics but it's too dark
keep in mind my car is lowered quite a bit.
Modified by DsR at 3:38 PM 2/4/2004
I have the DC on stock suspension and am yet to encounter any problems. Large speedbumps havent been a problem either, it really isnt as bad as people make it out to be, just drive carefully.
Dc hangs low.
I scratched it pretty good on stock suspension.
I would not buy it again, especially now that I have a new suspension on the way.
The difference is not so great as to sway me to the DC... The OEM JDM header is good enough.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAVEDIGGER »</TD></TR><TR><TD CLASS="quote">DC,cheaper,lighter,and great gains for about $280 or so</TD></TR></TABLE>
Where do you find it for 280???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr 00 0108 »</TD></TR><TR><TD CLASS="quote">
Where do you find it for 280???</TD></TR></TABLE>
Not new, thats for sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAVEDIGGER »</TD></TR><TR><TD CLASS="quote">$276 brand new from HP</TD></TR></TABLE>
I see 340.
I see 340.
The DC is pretty sweet for the money. I had one on a '00 I bought. When it came time to sell it, I put the stock manifold back on and felt a significant power difference (wasn't just mental either). Keep in mind you'll need a different cat too, of course. BTW it was all beat to hell on the bottom from the previous owner "lowering" the car with crappy Neuspeed springs.
you must have looked at stainless. Acura Integra Type R 4-1 in ceramic is $276. Ask for Andy and tell Him RYAN sent you and you might get $5-$10 off list.
