Couple quick questions please help me need to pass inspection
Old Feb 4, 2004 | 08:12 AM
deftones0817's Avatar
Default Couple quick questions please help me need to pass inspection
Can I adjust the eacv? It has a think shaped like a house sorta can i buy a tool to compress the spring? If so what tool do I need?
Second anyone know where i can get a good deal on a eacv?
Third anyone have that link to what to check for idle surges? I can find link
This is a 89 honda crx hf with stock motor 1.5 mpfi I need to get this car through inspection and its idleing at 1400 rpms now and then after a few minutes it starts surging. I cleaned teh air temp sensor it was full of gunk i sprayed out the intake manifold with cleaner. I cleaned the eacv once. After I did all this the problem went away for about 45 minutes then the surging came back.
How do I adjust idle? Thanks guys in advance. I need to get this through my other car died last night(stupid mustang) and I need my crx to run now. Can drive with no tags.
DEF
Old Feb 4, 2004 | 09:04 AM
Matty.'s Avatar
Default Re: Couple quick questions please help me need to pass inspection (deftones0817)
sounds like a vacuum leak.
check all wiring to sensors and all vacuum lines first.
Old Feb 4, 2004 | 09:30 AM
Default Re: Couple quick questions please help me need to pass inspection (gumtape_deathmatch)
checked it already not a vaccum leak and im pretty sure its just in need of a real big tune up.
DEF
Old Feb 4, 2004 | 10:24 AM
tgreaves's Avatar
What inspection do you need to go through.. Emissions or state inspection.. If its state just get a fake sticker.. The shop where your getting it done doesnt care if your car is safe for the road and neither does the state.. They all just want your money..
Old Feb 4, 2004 | 11:03 AM
Default Re: Couple quick questions please help me need to pass inspection (tgreaves)
well i live in delaware and delaware motor vehicles checks it and I have to make it pass.
DEF
Old Feb 4, 2004 | 11:11 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deftones0817 &raquo;</TD></TR><TR><TD CLASS="quote">well i live in delaware and delaware motor vehicles checks it and I have to make it pass.
DEF</TD></TR></TABLE>
Oh.. That sucks.. Well just go to the junkyard and get a new eacv.. If you cleaned it and it worked for 45 minutes or so then its surely that.. You can pick one up for like $10.00 at a local junk yard.. One thing you can do it unplug the eacv and see if the idle keeps surging.. If it fixed it then the eacv is the problem..
Old Feb 4, 2004 | 11:38 AM
dc2_and_ef's Avatar
i also had an idel surge and found that my idle was higher than the ecu could handle thus making it surge. turned it down never happened again
Old Feb 4, 2004 | 12:05 PM
tgreaves's Avatar
Default Re: (dc2_and_ef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2_and_ef &raquo;</TD></TR><TR><TD CLASS="quote">i also had an idel surge and found that my idle was higher than the ecu could handle thus making it surge. turned it down never happened again</TD></TR></TABLE>
Forgot about that.. If the motor revvs above a certant rpm and the ecu doesnt see the tps sensor showing the throttle isnt opening.. It will cut fuel.. That might cause the jumping idle..
Old Feb 4, 2004 | 12:43 PM
I had car started and when it start surging i unplugged the eacv and the car idled fine...so im guessing i need a new eacv if anyone has one please let me know...i dont know if ill pass emissions wiht this surge....
DEF
asianrepnsb
12
Mar 8, 2008 12:26 PM
ballinsk8er
Mar 20, 2007 07:00 PM
tico
10
Aug 7, 2006 10:37 PM
SA22C
Oct 2, 2005 09:42 AM
