F20B vs. B series.
Old Feb 4, 2004 | 07:29 AM
my_slow_civic's Avatar
Default F20B vs. B series.
Alright, here is where I stand. I used to own a 4th gen, with a b20/vtec in it. I had the opportunity to go with a F20B. Not wanting to hack up the 4th gen chassis, I sold that, and picked up a 5th gen, with a b16 in it. Now, as I get closer to obtaining the F20B, I am starting to get a little gun shy of the motor. I work at a speed shop, and the owner has the f20 in his hatch. He needs to ditch this, to go with a h22a, so he can achive his goal of nines. Anyways, he will trade his motor/tranny harness setup, for my motor tranny setup. I just need to purchase mounts, and axles. I know the motor runs strong, and I have performed a compression and leak down check on the motor, so I am not concerned that it is bad.
My problem is, I am not familiar with the f/h series motors. I believe it is great opportunity to grab a F20, for almost free. But again, have been stuck on b series, and have never really messed with the h and f's.
If you were put in this position, would you go with the trade? Or stick to what you know?
Old Feb 4, 2004 | 11:57 AM
indomotor's Avatar
Default Re: F20B vs. B series. (my_slow_civic)
Always try to stick to what you like and know...Peeps have different set up but you need to do what make you happy.Good luck.....
Old Feb 4, 2004 | 01:51 PM
Default Re: F20B vs. B series. (indomotor)
But we all have to take a step, I know that. I guess I am wondering, is the f20 really that much better over a good b20/vtec setup?
Old Feb 4, 2004 | 02:35 PM
satan_srv's Avatar
F20B is a really nice High revving motor. The crank and rods are really strong compared to most of the production engines...it can really take a beating. It already has type-s cams and 11:1 compression.
A set of skunk2 cams in there and a final drive and it will haul ***. the user f20Bcivic had an F20B in a hatch so you could ask him what he thinks of it.
Remember the F20B is where the F20C came from, it was the testbed for the S2000 design.
Old Feb 4, 2004 | 03:01 PM
H25's Avatar
H25
Default Re: F20B vs. B series. (satan_srv)
f20b= too small of bore.. not enough stroke.. do a search this subject was talked about on another thread... b20vtec will out run a f20b.. ill take a 85 bore 89mm stroke motor over 85bore by 87 stroke any day of the week.
Old Feb 4, 2004 | 03:08 PM
satan_srv's Avatar
Default Re: F20B vs. B series. (MHRacing-310)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MHRacing-310 &raquo;</TD></TR><TR><TD CLASS="quote">f20b= too small of bore.. not enough stroke.. do a search this subject was talked about on another thread... b20vtec will out run a f20b.. ill take a 85 bore 89mm stroke motor over 85bore by 87 stroke any day of the week. </TD></TR></TABLE>
F20B is 88mm stroke by the way...
but I would probably say the B20/VTEC is a lighter motor.
Old Feb 4, 2004 | 03:33 PM
I have read every thread that came up with F20B as the search subject.
Old Feb 4, 2004 | 05:19 PM
phatrick2332's Avatar
has anybody though of, or done and f22b1? 142 hp 143 ftlbs
Old Feb 5, 2004 | 04:47 AM
f20bcivic hasnt been active since November.
As for weight goes, I have only been able to find that the f20/h22 weighs in at 75lbs more than a b18c? Is that accurate? How about the tranny?
Old Mar 27, 2004 | 06:37 PM
cpforyou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my_slow_civic &raquo;</TD></TR><TR><TD CLASS="quote">f20bcivic hasnt been active since November.
I heard he took everything apart so he could go towards turbo. I've seen him at the tracks awhile with his old setup. It was a Civic Hatchback w/ F20B (Stock Block, Upgraded Valvetrain and JUN3 Cams). With drag radials, he was hitting low 13s. With slicks, he's easily into the 12s.
Old Mar 27, 2004 | 06:42 PM
satan_srv's Avatar
Default Re: F20B vs. B series. (cpforyou)
yeah last time I talked to minh he said he was going for a turbo setup.
Old Apr 9, 2004 | 08:09 PM
H25's Avatar
H25
if your really down for the f20b block because you want a motor you can rev high and still have good longevity... resleeve it and go 89mm bore. and use a h22a head. the valves are smaller diameter then a h22a.. and get some nice cams..
Old Apr 21, 2004 | 12:17 PM
Well, the motor was dropped in my hatch, using a fatty turbo head gasket, since the wrong head gasket was ordered.
Right now, I am very dis-satisfied with the motor, and almost regret going this route.
Old Apr 21, 2004 | 02:51 PM
Maintenance's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my_slow_civic &raquo;</TD></TR><TR><TD CLASS="quote">Well, the motor was dropped in my hatch, using a fatty turbo head gasket, since the wrong head gasket was ordered.
Right now, I am very dis-satisfied with the motor, and almost regret going this route.</TD></TR></TABLE>
What were you not sastified with? Was it with the performance? Did get a chance to ride in his car when he had the f20b? I'm just curious.
Old Apr 21, 2004 | 03:19 PM
GSRswapandslow.
Guest
Posts: n/a
the f20b cams ARE NOT TYPE S CAMS
but there is an F20b being built right now that will give hte final word as to if they are worth it or not...
but, if you have a civic/integra/crx go with a b-series
if you have an accord/prelude go wiht an f20b
Old Apr 21, 2004 | 05:42 PM
goforbroke's Avatar
MEAT PATTY
Default Re: (Ej6andslow)
Can you explain this?
Old Apr 21, 2004 | 06:32 PM
GSRswapandslow.
Guest
Posts: n/a
they are smaller than the Type S cams
Jdogg on here has one...and we took the cams out and measured...the Type S cams are in fact larger
Old Apr 21, 2004 | 07:06 PM
donz's Avatar
are you sure, that the f20b cams aren't type s cams? It has been written on here many times that they are. However I don't have one or ever measured. Maybe he measureed the cams from the f20a? the auto one is supposedly weaker.
Also why a turbo head gasket? wouldn't you want something a little thinner, or stock to keep the 11:1 compression?
Old Apr 21, 2004 | 08:27 PM
f@sth@tch89's Avatar
Default Re: (donz)
will the mounts for an h22 swap into an EF work for a f20b? if you can swap this motor in and put the h22 head on it then it sounds like its worth it. bore it out to 89mm and get a crank that would give u a 95 mm stroke. hell if there is an adapter plate for a b-series tranny then that would be even sweeter.
But to answer the original post...i would say think out of the box and be different. but the bottom line is your wallet.
Old Apr 21, 2004 | 09:37 PM
JDogg's Avatar
Default Re: (fasthatch89)
i have a set of type s cams sitting right next to my f20b cams... they are obviously smaller.
yall started on my **** yet rob?
Old Apr 22, 2004 | 03:20 AM
GSRswapandslow.
Guest
Posts: n/a
I told you i was doing the exhaust side of your head , so....we gotta fix that first
Old Apr 22, 2004 | 07:39 PM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">
but I would probably say the B20/VTEC is a lighter motor.</TD></TR></TABLE>
I thought the F20B had an 87mm bore and 85mm stroke.
Old Apr 22, 2004 | 07:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MHRacing-310 &raquo;</TD></TR><TR><TD CLASS="quote">if your really down for the f20b block because you want a motor you can rev high and still have good longevity... resleeve it and go 89mm bore. and use a h22a head. the valves are smaller diameter then a h22a.. and get some nice cams.. </TD></TR></TABLE>
Also, the H22A head will not work. The F20 is MUCH more closely related to the K-series than the H-series.
Old Apr 22, 2004 | 07:47 PM
JDogg's Avatar
Default Re: F20B vs. B series. (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">
Also, the H22A head will not work. The F20 is MUCH more closely related to the K-series than the H-series.</TD></TR></TABLE>
what are you talking about...... we are NOT talking about the f20c s2000 motor.
the f20b is close to an h22, the head will bolt up
Old Apr 23, 2004 | 03:49 PM
Default Re: F20B vs. B series. (racerxfear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerxfear &raquo;</TD></TR><TR><TD CLASS="quote">
What were you not sastified with? Was it with the performance? Did get a chance to ride in his car when he had the f20b? I'm just curious.</TD></TR></TABLE>
Slower than expected.
Riding in the car that the motor was pulled from, really wouldnt allow me to compare. The car weighed next to nothing.
