please help with dpfi to mpfi distributer
Old Feb 4, 2004 | 07:21 AM
bseriesboosted's Avatar
Default please help with dpfi to mpfi distributer
ok i have all the wiring diagrams and instructions but my question is what to do about the distributer the dx harness doesn't have a plug to fit so what am i supposed to do go get a new plug and cut and solder it on to the harness or what im at a loss on this one
also i am having to put vtec on a toggle switch does anyone here know how i can do that
Modified by bseriesboosted at 12:05 PM 2/4/2004
Old Feb 4, 2004 | 07:58 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: please help with dpfi to mpfi distributer (bseriesboosted)
I used the Si style plug on my DX harness..
No,You don't have to cut and solder,
Just release the pins from the DX connector and insert them
into the Si type connector..
Old Feb 4, 2004 | 08:59 AM
redeyeef2's Avatar
Yes you need the round plug from an si to do it correctly. I would not recommend cutting the wires, rather de-pin them and re-install them on the new plug. If the si plug is unavailable you can revert an si distributor to a dx square plug and run your other two wires external.
http://www.redeyefabrication.com
Old Feb 4, 2004 | 09:07 AM
Foowee's Avatar
find some sewing needels or a pick set. they will help you de-pin the plug.
Old Feb 4, 2004 | 09:56 AM
Default Re: please help with dpfi to mpfi distributer (Foowee)
does anyone have a write up on how to change the si plug to the dx or can you just match up wire colors if you just match up colors then im sure i can pull it off any more info you can give me would be great
tia
thedudefromjerz
Feb 20, 2008 08:17 AM
aug
Jan 8, 2008 10:39 AM
SomeDude56
Sep 21, 2005 10:32 PM
88fgfd
May 24, 2004 07:06 PM
Kilohead36
Oct 19, 2003 10:48 AM
