AWFUL rubbing noise coming from rear tires...
There is some rust on the rear break pads/rotors. But there has been for a little while now. It just started 2 days ago...
It rubs on and off... it only rubs at a certain point of the tire rotation. I hear it from both sides...pretty sure. I can only hear it at low speeds, but i think the engine just drowns it out at higher speeds. It does come and go, and sometimes gets worse under breaking, but it occurs while just cruising in neutral aswell, or atleast thats when i can hear it best.
My only thoughts where that it was the rust finally taking effect...I'll pull the tire of this weekend and take a look at it.
so ur tires are rubbing not
the rotors right
cuz u said rust???
if ur tires are rubbing then it can only mean one thing bro
ur shocks are bad or u got to wide of a tire on their
the rotors right
cuz u said rust???
Well i'm not really sure what is rubbing.
There are Koni Yellows on there now, and 450lb gournd controls on the rear...
but it didn't always make that noise...only think i can think of is going over some speed bumps. the car bottomed out...could that of damaged it?
i was thinking maybe just raising the car up some...
which is it brakes or tires?
if the noise is made only when bottoming out on speedbumps or hard turning then its your tires and you wouldve heard it by now.
if the noise is metallic scraping and it oscillates sometimes then its your brake pads and they need to be replaced!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gumtape_deathmatch »</TD></TR><TR><TD CLASS="quote">which is it brakes or tires?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by issues4 »</TD></TR><TR><TD CLASS="quote">Well i'm not really sure what is rubbing.</TD></TR></TABLE>
I'll be taking a closer look at it later on tonight...i'll let you guys know.
Alrighty...took a good look at it (in the light this time)...and the rotor is torn to shreds. A good half of the width is scraped deep enough to feel rough.
Looks like new pads and rotors are going on my shopping list...
Its only on the back left wheel though...i'm wondering how it happened. I thought maybe something got caught betweent the pad and the rotor, but there's no room for that...
RanCRX
Feb 24, 2012 10:59 PM
johnqt3
13
Dec 12, 2004 08:26 AM
