4th to 5th gear grind at high RPMs
Old Feb 3, 2004 | 07:56 PM
Xymox007's Avatar
Default 4th to 5th gear grind at high RPMs
If I'm traveling at 75mph and drop it down to 4th gear and then into 5th I get this annoying grind when I'm pushing from 4th gear into 5th gear. It does not happen at lower RPMs, only at higher RPMs. Synchro's?
What's going on here? I have a 1998 GS-R with 50K miles.
Thanks.
Old Feb 3, 2004 | 08:11 PM
civic_rider's Avatar
Default Re: 4th to 5th gear grind at high RPMs (Xymox007)
YUP! 4th Gear synchro!
I had the same problem with my 3rd gear synchro on my 92 Si hatch (D16z6). It was $750 cdn to fix it - basically a tranny rebuild (unless you know trannys well enough to dismantle it completely and reassemble yourself)....so I just swapped in a new y8 engine WITH a y8 tranny for $1100 cdn.
now I'm selling my z6 tranny for $100. (with the 3rd gear synchro worn) to a guy who CAN do the labour himself. The synchro gear itself is cheap, but the labour is intensive.
Good Luck!
Old Feb 3, 2004 | 08:13 PM
Xymox007's Avatar
Default Re: 4th to 5th gear grind at high RPMs (civic_rider)
Holy crap. That's a ton of dough to spend on this car. No offense to the H loyalists, but I'm not about to spend that much money on this car. This sucks. I should have taken more into consideration when the previous owner told me his g/f spent some time behind the wheel when she was learning to drive stick.
Old Feb 3, 2004 | 08:16 PM
Synchro gears get worn when you do alot of fast, high-rpm shifting, with only a partly engaged clutch....
Old Feb 3, 2004 | 08:17 PM
Your Epitaph.'s Avatar
///M Power
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xymox007 &raquo;</TD></TR><TR><TD CLASS="quote">...the previous owner told me his g/f spent some time behind the wheel when she was learning to drive stick. </TD></TR></TABLE>
that'll do it...
Old Feb 3, 2004 | 08:18 PM
Xymox007's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_rider &raquo;</TD></TR><TR><TD CLASS="quote">Synchro gears get worn when you do alot of fast, high-rpm shifting, with only a partly engaged clutch....</TD></TR></TABLE>
So going with a racing type of clutch (if I would decide to rebuild) would be the best option. Because, I can assure you the clutch is to the floor.
Old Feb 3, 2004 | 10:08 PM
Nihilation's Avatar
I noticed with my car I can't go from WOT in 2nd or 3rd gear and then directly to 5th without it(5th) grinding. However, if I go through all the remaining gears, its fine.
Old Feb 4, 2004 | 07:25 AM
well ya a racing clutch would help. sol longs the clutch IS all the way engaged when you shift. Doesn't matter what KIND of clutch you have.
And yeah when YOU drive it,, the clutch IS probably all the way down, but for the first 1000,000kms when someone was "learning" is what most likely wore it down.... :D
Old Feb 4, 2004 | 09:13 PM
Xymox007's Avatar
I'm going this route before I bite the bullet and spend the big bucks: https://honda-tech.com/zero...49469
Old Feb 5, 2004 | 07:08 AM
hey i've heard that stuff DOES actually work wonders for worn synchros...as a temporary fix...
good luck!
Old Feb 6, 2004 | 02:29 PM
Xymox007's Avatar
Temporary fix is good enough for me if I can get by for a few more months (read: new car).
Old Feb 6, 2004 | 05:46 PM
Kendall's Avatar
Actually, I've been using synchromesh for some months now, and my problem has been completely eliminated. I've yet to have a recurrance of my 3rd and 5th gear grinding problems.
Old Feb 11, 2004 | 02:12 PM
Xymox007's Avatar
Default Re: (Kendall)
Wow. only 25 miles and the difference is like night and day. I hadn't a clue this stuff would make such a dramatic difference.
Bye-bye 5th gear grind.
I <u>HIGHLY</u> recommend GM Synchromesh.
Old Feb 19, 2004 | 02:30 PM
Xymox007's Avatar
Default Re: (Xymox007)
Modified by Xymox007 at 11:24 PM 3/6/2004
Old Mar 6, 2004 | 01:24 AM
vtecvlow's Avatar
:: sighz:: =/ Xymox007.. my car just did that to me today.. now i have to go through a approx 750 to fix my tranny!.. that sucks *** =/ :: high rpm.. shift from 5th to 4th then back to 5th grind.. =/
Old Mar 6, 2004 | 06:16 AM
speedminded's Avatar
Default Re: (vtecvlow)
Before you repair anything I would replace the transmission fluid.
I would suggest Redline MTL or MT-90 (not sure which one for the 'tegs, they can tell you) I had the same problem with 3rd gear in my 300zx (as just about all do) and it smoothed it out perfectly...
http://www.redlineoil.com/frames/gearoil.htm
Old Mar 6, 2004 | 06:30 AM
Regular Series's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xymox007 &raquo;</TD></TR><TR><TD CLASS="quote">Holy crap. That's a ton of dough to spend on this car. No offense to the H loyalists, but I'm not about to spend that much money on this car. This sucks. I should have taken more into consideration when the previous owner told me his g/f spent some time behind the wheel when she was learning to drive stick. </TD></TR></TABLE>
Dude, it's a GS-R with 50k! It's worth some cash. It sucks that the synchro is worn, but on the other hand you have an excuse to get an ITR tranny.
I hope you gote a good price on it, though...
Old Mar 6, 2004 | 05:58 PM
xplanetearth420x's Avatar
Default Re: 4th to 5th gear grind at high RPMs (Regular Series)
bye bye to ur synchos time for some new ones
Old Mar 6, 2004 | 07:23 PM
Xymox007's Avatar
Default Re: 4th to 5th gear grind at high RPMs (xplanetearth420x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xplanetearth420x &raquo;</TD></TR><TR><TD CLASS="quote">bye bye to ur synchos time for some new ones</TD></TR></TABLE>
Actually, patience is key to my problem. You have to let the GM Synchromesh take its time to do it's magic. I've had about 1,000 miles on my car since the switch to Synchromesh, and everything operates to specs. I have no more 4th to 5th gear grinds whatsoever. Like I said, patience is key. You can't expect to dump in the new Synchromesh and cure the problem instantly. The car needs a few hundred/thousand miles until the problem is cured.
Old Mar 6, 2004 | 08:57 PM
oMek's Avatar
Default Re: (Grizzly Adams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grizzly Adams &raquo;</TD></TR><TR><TD CLASS="quote">Actually, I've been using synchromesh for some months now, and my problem has been completely eliminated. I've yet to have a recurrance of my 3rd and 5th gear grinding problems.</TD></TR></TABLE>
ive put about 6k since i put in the syncro mesh and its still working great, havent had 5th gear grind since
jordan_rael_420
Feb 26, 2009 05:05 AM
brlabrune
Feb 23, 2009 12:37 PM
92EG8
May 16, 2007 06:46 AM
torr
May 22, 2005 03:49 PM
MTR.18
Mar 27, 2005 08:11 AM
