cracked block near freeze plug is it fixable!!!! i wanted to drop motor in tomorrow HELP!!!
Old Feb 3, 2004 | 07:30 PM
quick1racer's Avatar
Default cracked block near freeze plug is it fixable!!!! i wanted to drop motor in tomorrow HELP!!!
I have a b18a lsvtec set up.
the block came from a integra ls automatic.
there was an extra coolant passage that wasn't being used so i tried putting a steel freeze plug in its palce and i guess it was to big and i hit it to hard!!!!
SO now i have a dime sized hole near the freeze plug.
there is no crack, but there is just a small hole.
IS THE BLOCK TOAST????????
i put a crap load of JB Weld over it will it work or will the coolant pressure be much. Would the heat play a major role in the JB Weld holding?
Old Feb 4, 2004 | 05:11 AM
virginia_dude's Avatar
Default Re: cracked block near freeze plug is it fixable!!!! i wanted to drop motor in tomorrow HELP!!! (qui
I would venture a guess it is toast. It might be reairible with the right equipment and the right people but would likely cost far more than its worth.
Old Feb 4, 2004 | 08:08 AM
Fkned's Avatar
You can try the jb weld if you don't mind pulling the motor again if it donesn't work,but the best thing would be to get it welded by a shop good w/aluminum.The people who post there blocks use epoxy to seal the hole from leaking,so it might work.Or you could try to drill the hole round and tap it for a plug,that should work I would think.
Old Feb 4, 2004 | 12:45 PM
Jared's Avatar
Do you have any pics? Don't hack it up by using jb weld and epoxy. At the very least, have someone weld it up.
Old Feb 6, 2004 | 12:21 AM
thanks for the help
i actually used the epoxy and i am now doubting it
what if i pull out the steel freeze plug and replace it with a sandwhich type rubber style freez plug.
i already dropped the motor in so it will be a bitch!!!!!!!!!!!!
thanks for the help
Old Feb 6, 2004 | 08:46 AM
owen_the_soyboy's Avatar
you can have any capable aluminum welder repair it properly
Old Feb 6, 2004 | 10:15 AM
Sliced Beard's Avatar
if you lived closer i would do it for free
Old Feb 6, 2004 | 11:56 AM
snoochtodanooch's Avatar
i think drilling, tapping and putting a bolt in it would work well.
Old Feb 6, 2004 | 01:20 PM
redlinetuning's Avatar
nickel size isn't that bad, drill & tap it.. then use MR.gasket sealer around the bolt and let it sit over night. you'll be ready after 24 hours.
digital sol
Welding / Fabrication
Jun 26, 2007 10:35 AM
TypeSLO
Jul 22, 2006 07:50 AM
RTW DC2R
May 31, 2006 04:47 PM
TylerB
13
Apr 23, 2006 03:58 PM
