Which spark plugs and wires are you runnin?
Old Feb 3, 2004 | 06:54 PM
HONDA-2NR's Avatar
Default Which spark plugs and wires are you runnin?
Im about to purchase new plugs and wires for my civic and was wondering what are you all running and how were they doing? Thanks
b16si's Avatar
Default Re: Which spark plugs and wires are you runnin? (HONDA-2NR)
NGK R and MSD 8.5mm wires
Old Feb 3, 2004 | 07:11 PM
HATCHingMN's Avatar
Default Re: Which spark plugs and wires are you runnin? (b16si)
NGK blue wire and stock plugs
Old Feb 3, 2004 | 07:12 PM
B2FiNiTY's Avatar
Default Re: Which spark plugs and wires are you runnin? (HATCHingMN)
Oem everything
Old Feb 3, 2004 | 07:15 PM
Ricey McRicerton's Avatar
Default Re: Which spark plugs and wires are you runnin? (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Oem everything </TD></TR></TABLE>
Same here..and Im making close to double my stock HP (by my guesses).
Old Feb 3, 2004 | 07:18 PM
Guam_CiviC619's Avatar
Magnecore and NGK.
I Would like to try these 1 day.
and these
Old Feb 3, 2004 | 07:21 PM
Newman's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDA-2NR &raquo;</TD></TR><TR><TD CLASS="quote">Im about to purchase new plugs and wires for my civic and was wondering what are you all running and how were they doing? Thanks </TD></TR></TABLE>
All depends on your setup. If you're running a high compression setup or a setup with forced induction, then you want a colder plug (BKRE-6 or preferably 7 if you can find them). If you have a stock motor, the standard BKRE-5 plugs will work just fine. Same goes with wires... thicker wires (8.5mm - 10mm) will help out a little bit with more of a setup, but otherwise you can just stick with standard size plug wires or 8mm plug wires.
Old Feb 3, 2004 | 07:40 PM
Team 4R's Avatar
Default Re: Which spark plugs and wires are you runnin? (Newman)
from what i understand the magnecor wires are supposed to be best at conducting spark.
Old Feb 3, 2004 | 07:49 PM
Shawn C's Avatar
In The Garage
i'm running NGK BKR7E plugs (for turbo) and nology hotwires:
i think the wires give me too hot of a spark, so i'm about to sell them and get some ngk blues. NGK makes the best ignition components IMO
Old Feb 3, 2004 | 07:51 PM
The Internet Tough Guy's Avatar
ngk oem. nothing better.
Old Feb 3, 2004 | 07:53 PM
splitime's Avatar
OEM wires, good stuff
stock require'd NGK plats.
Old Feb 3, 2004 | 09:14 PM
TABIAS's Avatar
I want to be MADE into Ice-T
Default Re: Which spark plugs and wires are you runnin? (splitime)
all oem
Old Feb 3, 2004 | 09:24 PM
RangerDan's Avatar
Default Re: Which spark plugs and wires are you runnin? (preacherboy)
OEM all the way. Tried some aftermarket wires...felt like I lost power.
Old Feb 3, 2004 | 11:00 PM
GRAVEDIGGER's Avatar
Default Re: Which spark plugs and wires are you runnin? (Guam_CiviC619)
oem plugs and wires on my B16
Old Feb 3, 2004 | 11:03 PM
ProEater's Avatar
Default Re: Which spark plugs and wires are you runnin? (GRAVEDIGGER)
ngk wires and zex plugs
Old Feb 4, 2004 | 12:07 AM
Civic1.6VTEC's Avatar
Default Re: Which spark plugs and wires are you runnin? (ProEater)
NGK plugs and blue wires.
Modified by Civic1.6VTEC at 4:17 AM 2/4/2004
Old Feb 4, 2004 | 12:11 AM
distortedfuture's Avatar
Default Re: Which spark plugs and wires are you runnin? (Civic1.6VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic1.6VTEC &raquo;</TD></TR><TR><TD CLASS="quote">NGK plus and blue wires.</TD></TR></TABLE>
same
Old Feb 4, 2004 | 12:14 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: Which spark plugs and wires are you runnin? (distortedfuture)
stock NGK's and MSD wires.
Those splitfires are a waste IMO.....
think about it. Electricity takes the path of least resistance, right???
Well, when it splits off 3 or 4 or however many ways it does....disrupts the path
Old Feb 4, 2004 | 12:38 AM
E-brake or Handbrake's Avatar
Default Re: Which spark plugs and wires are you runnin? (Emerika)
I've heard great things with NGK
One of them it being Stockers.
Old Feb 4, 2004 | 01:09 AM
d0nkeyxPunch's Avatar
Banned
Default Re: Which spark plugs and wires are you runnin? (EJ1Z6)
OEM Sumitomo plug wires and NGK-R plugs
Old Feb 4, 2004 | 02:01 AM
T.J.'s Avatar
NGK plugs and oem wires
Old Feb 4, 2004 | 04:31 AM
B_Something's Avatar
NGK or factory
Old Feb 4, 2004 | 04:35 AM
ki3t's Avatar
This user can set his title.
Default Re: Which spark plugs and wires are you runnin? (Skunk2whore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk2whore &raquo;</TD></TR><TR><TD CLASS="quote">NGK plugs and oem wires</TD></TR></TABLE>
Same here buddy. OEM is ok to though.
Old Feb 4, 2004 | 04:56 AM
Knightmare69's Avatar
Default Re: Which spark plugs and wires are you runnin? (Ki3t)
NGK's and Bosch wires with lifetime warranty. I'm thinking of tryin OEM wires to compare but my GF's car is stock cept for intake and free-flow cat so I'm not to bothered with it.
Old Feb 4, 2004 | 05:27 AM
Jimmy's Avatar
Global Moderator
NGK Blues (wires) & Ngk plugs
