Rubbing alcohol? does it really help emissions?
Old Feb 3, 2004 | 05:40 PM
Propulsion's Avatar
Default Rubbing alcohol? does it really help emissions?
is it true if you put rubbing alcohol in your gas, it'll reduce the emissions? just failed smog (HC), need some tricks.
Old Feb 3, 2004 | 06:12 PM
ultimatehonda's Avatar
Default Re: Rubbing alcohol? does it really help emissions? (SilverCIVIC96)
It may be possible but I have never heard of that. Do you have any mods that would cause your car to not pass smog? If its stock maybe you can check your timing, and do some maintence to get the car to burner cleaner.
Old Feb 3, 2004 | 06:23 PM
JDMHN8's Avatar
Default Re: Rubbing alcohol? does it really help emissions? (ultimatehonda)
First of all, it's not rubbing alcohol that you add (as that is mostly water anyway), it's the alcohol based fuel additives designed to remove water from you tank. HEET is a prime example, and yes, it will affect your emissions in a positive way. Quite a few people have documented how it works, so go ahead and search...
Old Feb 3, 2004 | 11:18 PM
ALLBLINE's Avatar
Default Re: Rubbing alcohol? does it really help emissions? (JDMDA9)
Stupid as i was when i was younger,i threw in a bottle of rubbing alcohol and drove around for 15 minutes and amazingly i passed.Dont reccommend that nowadays,unless you can't afford to fix the problem in your car good luck!
Old Nov 30, 2006 | 06:32 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default Re: Rubbing alcohol? does it really help emissions? (Propulsion)
bump
What type of alcohol and where can I get it quickly?
Home depot and shoppers drug mart had nothing of the sort
Old Nov 30, 2006 | 09:15 PM
ITR#132's Avatar
Default Re: Rubbing alcohol? does it really help emissions? (PINKS)
toulene or acetone (nail polish remover)
Old Dec 1, 2006 | 12:32 PM
jonvo's Avatar
Default Re: Rubbing alcohol? does it really help emissions? (ITR#132)
i used denatured alcohol
Old Dec 1, 2006 | 01:47 PM
Flashmn's Avatar
Default Re: Rubbing alcohol? does it really help emissions? (jonvo)
methanol.
_ijayyy
Jul 4, 2012 01:49 AM
slayersluck
Engine Management and Tuning
Mar 6, 2009 04:32 PM
jerbou71
12
Aug 23, 2006 05:46 PM
Luserkid
15
Sep 5, 2003 03:44 AM
customx_
Mar 12, 2003 10:50 AM
