Horn pin replacement part? I need the part name??.
Old Feb 3, 2004 | 05:05 PM
OptimusPrimeX's Avatar
Default Horn pin replacement part? I need the part name??.
My horn kept going off, and while trying to fix it, i tried to jimmy rig the clip that i believe is a ground, or constant current....... which didn't work.
I'm not sure what the actual part name of the clip would be, and since the fuse is tied in with the break lights, i have no break lights now
the clip is gold, and bends straight into the rear of the steering wheel - if you take off the ignition cover you'll see the clip on the bottom left side.
Does anyone know the part name?.. i'm not sure what to order... and its a real joy not having a horn or breaks
*did a search*
http://www.hondaautomotivepart...SI%29
Old Feb 3, 2004 | 07:15 PM
Default Re: Horn pin replacement part? I need the part name??. (OptimusPrimeX)
bump (^-0-^)
..anyone??
here's a link
Redek4
May 11, 2010 01:02 PM
1low91s10
Feb 20, 2008 05:55 PM
sleepercivic69
Nov 11, 2006 11:18 AM
OptimusPrimeX
Feb 3, 2004 02:37 PM
xcathodex
Mar 12, 2003 06:55 PM
