Slow blowing blower motor, any known alternatives???
Old Feb 3, 2004 | 04:35 PM
UNCVLZD's Avatar
Default Slow blowing blower motor, any known alternatives???
My '91 CRX blower motor blows very slowly and sometimes not at all. I went to an auto parts store and the kid there said even the new ones suck (he had the same problem in a '90). Does anyone know of a fast-blowing one from another car is a direct swap? Please let me know, it's COLD!
Old Feb 3, 2004 | 04:54 PM
JonGP4's Avatar
Default Re: Slow blowing blower motor, any known alternatives??? (mattoien)
whats might help u out is if you take out ur evaporator and see if its got leaves and **** inside of it.. . i hear its pretty common and all that restriction is proably what makes it seem to blow out slow
Old Feb 3, 2004 | 09:04 PM
UNCVLZD's Avatar
Thanks, Bro. I'll give it a shot, but just in case, does anyone else know of a blower motor swap?
Old Feb 3, 2004 | 09:09 PM
JonGP4's Avatar
Default Re: (mattoien)
the motors theyselves are the same used in almost every honda.. only thing different is the mounting or the fins.. idealing i'd like to get the accord blower motors, they are alittle different, but i've tryed many times to get it to fit.. let me put it to u this way.. its abotu 3 times the size, uses dual fans.. and blows the oppsite way..
so yeah.. nuff said.. good luck
Old Feb 3, 2004 | 09:15 PM
UNCVLZD's Avatar
Well, are there any that spin the right way, are the same size, have the same mounting holes, and spin a teeny-bit faster?
Old Feb 3, 2004 | 09:18 PM
UNCVLZD's Avatar
It's possible for a motor to look the same on the outside, and be really different on the in.
Old Feb 3, 2004 | 10:49 PM
Louie B.'s Avatar
if they have the same electrical conector, and the same bolt patern, then they should work.... I've had to replace the blower on both my 91 Civic (worn out brushes - sounds like the problem you're experiancing - got another 88-91 from the junkyard) and my ex-wife's 97 Civic and both blowers looked very similar. I didn't get a chance to try one in the other car but If you can find one cheap/free it may be worth a shot! good luck getting the old fan out, mine was really stubborn (had to loosen the entire heater box to make enough room to get it out)
Old Feb 4, 2004 | 08:41 AM
UNCVLZD's Avatar
Default Re: (thumpu77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thumpu77 &raquo;</TD></TR><TR><TD CLASS="quote">(had to loosen the entire heater box to make enough room to get it out)</TD></TR></TABLE>
Luckily in the CRX the blower is mounted vertical instead of horizontal. Thanks for your suggestions.
mgreen992
Honda Civic (2001 - 2005)
Sep 17, 2016 12:27 AM
CooBreeze
Dec 30, 2009 10:57 AM
95 vtec
Nov 17, 2006 07:05 AM
civicwagonman
Jul 1, 2004 07:14 PM
bzyrice
Acura TL, RL & ZDX
Apr 9, 2003 08:52 PM
