Auto CRX : should I get it?
Old Feb 3, 2004 | 04:11 PM
thrty8street's Avatar
Default Auto CRX : should I get it?
I found a really good deal on a crx but the only problem is that it is an auto.
I am going to replace it with a b16 anyways but .....will the fact that it is an auto complicate the swap?
i know i will need another ECU, anything else i need in particular?
Old Feb 3, 2004 | 04:13 PM
onePOINTsix's Avatar
Default Re: Auto CRX : should I get it? (thrty8street)
yes, a manual pedal assambly, is the car a Si? if so i'll be more then willing to buy your ecu when you do the B16 swap
Old Feb 3, 2004 | 04:55 PM
goforbroke's Avatar
MEAT PATTY
Default Re: Auto CRX : should I get it? (Sideout)
Dude its easy, just get the pedals and assembly out of manual crx, the lines and holes are already ran for you.
Old Feb 3, 2004 | 04:57 PM
SIRX's Avatar
Vinceg99 did an auto to manual swap pm him about it
Old Feb 3, 2004 | 05:01 PM
X-Static's Avatar
Default Re: Auto CRX : should I get it? (SIRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideout &raquo;</TD></TR><TR><TD CLASS="quote">yes, a manual pedal assambly, is the car a Si? if so i'll be more then willing to buy your ecu when you do the B16 swap</TD></TR></TABLE>
im pretty sure only the DX came in automatic..
Old Feb 3, 2004 | 05:12 PM
Dwight Schrute's Avatar
Default Re: Auto CRX : should I get it? (X-Static)
i read in another thread, that in canada, they had automatic si's
o yeah, i just got a 90 crx si , y-49 too. i just learned about the curse today
Old Feb 3, 2004 | 07:21 PM
X-Static's Avatar
Default Re: Auto CRX : should I get it? (drewthomas14)
hehe...i knew what i was getting into, but i love it. I didnt plan on going y-49 and to tell you the truth didnt like it all that much at first but it def grew on me. So far the curse has been mild, only 6 minor wrecks so far
Old Feb 3, 2004 | 07:53 PM
RCautoworks's Avatar
I have done many auto to manual swaps, I have a lot of info on them to. Need any help feel free to IM me. Here is basically what needs to be done.
Stuff you will need
Manual trans
Manual flywheel
Manual flywheel bolts
Manual Ecu
Shift linkage
Shifter
Pedals
Side trans mount and rear trans mount from a manual, the pedals will probably be the hardest part. Here is some more wiring to help you out.
Installing the pedals (have fun):
This part sucks. Droping steering column and removing drivers seat makes life easier at this part. I cannot tell you how many nuts hold the assembly to the car, i can say it is all nuts though. One is really tricky to find and get to. You need a swivle, deepwell 12mm and 2 six inch extensions. It is above the air vents and steering column. Have fun getting it out. Remove cotter pin that holds brake pedal to brake booster. There is also a nut and bolt for it. Remove the gas pedal from automatic pedal assembly and move to manual assembly so the cable plugs up, or switch cable. Install the clutch cable through gromet that honda left on firewall in factory location. Rebolt all the nuts to the car that hold the pedal assembly.
Removal of the transmission:
To remove the transmission (you should know how to do this otherwise don't attempt). Please check my work with a chiltons or haynes manual as i will not be held responcible for damages that incure from this install. Remove both axels. Unbolt the bellhousing, remove the mounts (3 of them) and remove transmission, this is a unusually large tranny, it might require the whole engine coming out depended on how patient you are. I had the whole thing out cause i was putting a DOHC ZC in. Unbolt the torque converter from the motor, install flywheel (make sure not to reuse automatic flywheel bolts).
Installing shift linkage
This is a fairly simple task, remove the old auto shifter by removing 2 bolts on top and 2 on bottom. Then drill 2 holes where honda welded over them as picture below. Then simply install as a normal linkage would be. Take a piece of thin metal and glue to a piece of abs plastic and epoxy it on, the metal is to deflect heat and the plastic is to keep the heat form transfering inside.
Installing the transmission:
Torqure manual flywheel bolts down at 76 footpounds of torque. Install clutch with alignment tool, torque bolts down to 25 ft lbs. Before you install it all back there is one extremely important thing about the rear mount. Honda left 2 spots to mount the rear mount with 3 sets of holes, two are threaded, one is not. You need to move the mount location to the one that is threaded and then thread the other and place a bolt in there. Reassemble as specified in honda manual. Put new manual axels in.
Wiring with diagrams:
Drag two wires from under the hood (yellow and green on tranny) for the reverse lights to work when you are in reverse. Please note that the R light on the instrument cluster will not work without some decent knowledge of relay wiring. Connect these to wires to the ones pictured below
I found this one out the hard way, the key will not come out unless the car is in park and um, you dont have a park anymore. To fix this you can make the car think its in park all the time. Please understand, by doing this the P will be on in the instrument cluster all the time. This can be corrected one of 2 ways, disconneting the light or some extensive relay work.
This one is needed to crank the car because it no longer has a neutral or park. It is one of two plugs with only 2 wires. This one is easy to spot because it has two heavy black wires instead of the other with two yellow wires. Just connect them in a simple loop, or with some relay work to the clutch pedal because some decent current goes through them directly to the starter. I just left it like picture and allways crank the car with my foot on the clutch.
Old Feb 4, 2004 | 03:23 PM
hey thanks for all the replies all have been really helpful.
Old Feb 5, 2004 | 04:33 PM
Default Re: (thrty8street)
oh yeah about how much money are we talking about EXTRA to switch over to manual?
Old Feb 5, 2004 | 04:49 PM
Ef Whore's Avatar
I would suggest waiting for a decent manual transmission to come along....the trans swap is possible but I'd just rather have a true manual.
Old Feb 5, 2004 | 04:55 PM
BAZ's Avatar
BAZ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewthomas14 &raquo;</TD></TR><TR><TD CLASS="quote">i read in another thread, that in canada, they had automatic si's
o yeah, i just got a 90 crx si , y-49 too. i just learned about the curse today </TD></TR></TABLE>
Join the club, Y-49 for life!
Old Feb 6, 2004 | 12:18 AM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewthomas14 &raquo;</TD></TR><TR><TD CLASS="quote">i read in another thread, that in canada, they had automatic si's </TD></TR></TABLE>
NO. They NEVER did. Can we put this roumor to bed, please.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xstatic &raquo;</TD></TR><TR><TD CLASS="quote">
im pretty sure only the DX came in automatic..</TD></TR></TABLE>
X static is correct.
There NEVER were ANY auto trans CRX Si's, anywhere in North America.
I finally have the Canadian CRX sales brochures. And it says right in them CRX Si + A/T= N/A I can post the pages if theres anyone who doesn't believe me.
Old Feb 6, 2004 | 07:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street &raquo;</TD></TR><TR><TD CLASS="quote">oh yeah about how much money are we talking about EXTRA to switch over to manual? </TD></TR></TABLE>
up
Old Feb 7, 2004 | 07:22 PM
SoLowCRX's Avatar
If you got a good deal on it, get it. Auto to manual swap is easy... and you don't need a new ecu. Some simple wiring is all you need. The car needs to think its in park to release the key from the ignition and to start. SIMPLE! I did it to my CRX, took 7 hours.
Old Feb 8, 2004 | 09:43 AM
Default Re: Auto CRX : should I get it? (SoLowCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoLowCRX &raquo;</TD></TR><TR><TD CLASS="quote">and you don't need a new ecu. Some simple wiring is all you need. </TD></TR></TABLE>
You need to solder the ecu or buy a hole new one. You made it seem like you don't need to do anything to the ecu which is wrong.
ryanangelo212
Dec 27, 2009 10:36 AM
killercrx91
14
Aug 24, 2009 03:37 PM
AJZerick
Jan 21, 2008 07:53 PM
jdmrider
Feb 21, 2006 08:55 AM
crxh22project
Nov 4, 2004 03:03 PM
