Fuel Injectors for a Type R
I have a 2000 Type R with a turbo in it and i am only running around 6 psi. You can see it at http://www.Scottstyper.s5.com . I am going to be putting an AEM EMS in it soon and i am thinking of upgrading the injectors. Will 440cc injectors fit with the stock fuel rail? ALso, what is the larges injectors i could put before i would have to get a new rail, or modify the one i have (i don't want to have to do that)? Thanks
i used bosch motorsport fuel injectors and they fitted straight into the stock fuel rail, i also did end up changing the fuel rail just to make sure though..
i'm running 550's and stock fuel rail and i don't push past 260whp.. stock fuel rail should support at least 300whp i would think.. you will need high pressure intank fuel pump to go along.
Matthew98DX
Oct 31, 2016 06:28 AM
K-Spec
Oct 25, 2006 02:28 PM
turboeg831
Oct 12, 2006 12:20 PM
