Trying to wire a GSR cluster into a 91 CRX Si...
Old Feb 3, 2004 | 01:56 PM
92TEGsrSC's Avatar
Default Trying to wire a GSR cluster into a 91 CRX Si...
Well, does anyone other than ghettocrxsi know how to do this? I looked at his website and my plugs seem to have different color wires in each slot for the GSR plugs and it makes me worried that maybe my plugs are from a 2000 GSR? (his site says to use 94-99 GSR plugs/cluster... anyway, should I just splice the wires listed from the CRX plugs into whichever color wire is in the slots he has listed??? has anyone used his conversion instructions?? I am not trying to screw this up... and also, there is a small 3-wire plug (I unplugged from each cluster) that he doesn't even meantion in his conversion instructions.. where/how do I wire these??? Someone please help me out. I FOOLISHLY already cut the plugs off the CRX expecting his instructions to be foolproof and feel like I may as well splice the plugs back together..... TIA
Zack
Old Feb 3, 2004 | 02:17 PM
Comp97GSR's Avatar
Default Re: Trying to wire a GSR cluster into a 91 CRX Si... (92TEGsrSC)
How does the speedo work since the CRX has a cable that drives the speedo?
Old Feb 3, 2004 | 07:02 PM
92TEGsrSC's Avatar
Default Re: Trying to wire a GSR cluster into a 91 CRX Si... (Comp97GSR)
you have to switch to an electric VSS (vehicle speed sensor). This is a non-issue because I'll be using a hydrolic tranny (which comes with an electric VSS).
I suppose the next logical question is how do I use a hydrolic tranny if the CRX is normally cable? lol Well, that is being taken care of the by conversion kit supplied by hasport for $200.
So now back to my original question
NRanella
Sep 22, 2008 06:27 PM
Mike17
Jan 21, 2005 05:51 AM
KustomCrx
Oct 11, 2004 10:08 AM
AgentJam
Feb 10, 2004 04:30 PM
DriveSideWays
Feb 2, 2004 04:57 AM
