Is there a difference in 5 lug usdm and jdm?
i have a jdm rear 5 lug but i need the new control arms and swing arm (mines is bent) is it the same as the usdm? because i went to acura and they are different part numbers so i don't know if it fits or not?
I am pretty sure that the lca's are the same. The uppers are different and for that matter the only thing different on the rear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi2004 »</TD></TR><TR><TD CLASS="quote">so should i order the control arms and and swing armn at acura if its the same?</TD></TR></TABLE>
you can, yes.. they should be the same..
the rear caliper bracket changed in us after 2000
euro changed after 98 i think
jdm probably 98 as well
the caliper brackets mount to the trailing arm and that part is not replacable
so you better get the right one before you order
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by owen_the_soyboy »</TD></TR><TR><TD CLASS="quote">when you say SWING ARM what are you referring to?</TD></TR></TABLE>
Just like when someone was asking about the "front spindle".
in the rear
the JDM ITR 5 lug has a wider "track"
the USDM ITR 5lug and CTR have the narrow "track" compared to the JDM ITR
correct me if i'm wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kid1320 »</TD></TR><TR><TD CLASS="quote">ithe JDM ITR 5 lug has a wider "track"
correct me if i'm wrong</TD></TR></TABLE>
Never once heard that!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed »</TD></TR><TR><TD CLASS="quote">
Never once heard that!</TD></TR></TABLE>
no? well i have a JDM 5lug with the 36mm axles up front. and a friend of mine has a USDM itr. my rears are closer to the fender than his, both sides. i'm probably wrong again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed »</TD></TR><TR><TD CLASS="quote">Are your rear LCAs on an ITR?
BTW ... I've had the JDM front hubs and 36mm axles on my turbo ITR. </TD></TR></TABLE>
both cars are 96-00 Ek chassis. both have SRR LCAs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black_GT »</TD></TR><TR><TD CLASS="quote">NO</TD></TR></TABLE>
??? NO?
??? NO?
