injector size
Old Feb 3, 2004 | 10:35 AM
vtec fan's Avatar
Default injector size
Hi guys I have a 90 accord with I/H/E, I m thinking obout some 290cc injectios would I see/feel a difference in my torque and horsepower out put. What is the difference between saturated , hold and peak which is recomended for N/A.
Old Feb 3, 2004 | 10:39 AM
kommon_sense's Avatar
Default Re: injector size (vtec fan)
bigger injectors won't help unless your setup needs more fuel. Unless you are turbo/nitrous/super or have a very built engine, then larger injectors are not needed. You might want to just have your stock injectors cleaned.
Old Feb 3, 2004 | 10:45 AM
vtec fan's Avatar
thanks for the info
Old Feb 3, 2004 | 10:49 AM
vtec fan's Avatar
I was looking in my haynes car care book and saw that the f22a1 and f23 engine have the same specs (bore /stroke, comp, and displacement) but the f22a1 makes only 125 hp while the f23 makes 140hp what is the difference between the two engines,
Charlie Moua
Oct 28, 2009 11:09 AM
sevret.t
Nov 23, 2004 06:39 PM
sparq
Jul 30, 2003 01:57 PM
sparq
Jan 7, 2003 08:53 AM
kaneda3
Dec 30, 2002 12:18 PM
