Free Buick GN 280cc injectors or $100 prelude 290ccs
Old Feb 3, 2004 | 10:25 AM
Casey's Avatar
Default Free Buick GN 280cc injectors or $100 prelude 290ccs
I need to upgrade my injectors to something a little bit larger than stock and was considering prelude injectors. I just spent a ton of money on the head so the cheaper the better. I can get used prelude injectors for 100 bucks, which is a good deal, but still, its 100 bucks. The guy that tunes my car gave me some buick GN injectors. They are old, but all flow(tested them). The only downside to the GN injectors is that Ill have to bore out the fuel rail and the IM for the new injectors, theyre slightly bigger. He has the right bit and I know hes capable of it, but would you do it? Any suggestions? Thanks
Old Feb 3, 2004 | 01:59 PM
red civic standard's Avatar
Default Re: Free Buick GN 280cc injectors or $100 prelude 290ccs (Casey)
i say spend the $100
Old Feb 3, 2004 | 03:36 PM
dfoxengr's Avatar
Default Re: Free Buick GN 280cc injectors or $100 prelude 290ccs (red civic standard)
whats the setup, you may not even need to.
Old Feb 3, 2004 | 03:42 PM
WAFFLES's Avatar
Use the freebies.
Old Feb 3, 2004 | 05:25 PM
SkRiBLaH's Avatar
Default Re: Free Buick GN 280cc injectors or $100 prelude 290ccs (WAFFLES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES &raquo;</TD></TR><TR><TD CLASS="quote">Use the freebies.</TD></TR></TABLE>
Old Feb 3, 2004 | 05:39 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
No, I would just get injectors that are meant to fit in there. It might be hard to upgrade again if you bore those spots out.
Old Feb 3, 2004 | 05:42 PM
Casey's Avatar
Default Re: (v-attack)
i already maxed out stock injectors, so yes i need something bigger. as for boring them out, all i have to do is buy injectors with an "american" bore to them, mustang injectors, camaro, etc
Old Feb 3, 2004 | 05:45 PM
dfoxengr's Avatar
Default Re: (Casey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey &raquo;</TD></TR><TR><TD CLASS="quote">i already maxed out stock injectors, so yes i need something bigger. as for boring them out, all i have to do is buy injectors with an "american" bore to them, mustang injectors, camaro, etc</TD></TR></TABLE>
then you have to think about length etc. get the ludes.
Old Feb 3, 2004 | 05:55 PM
BolivianDc2's Avatar
Default Re: (hybridvteceg)
get the prelude, but 100 is damn expensive for them. If you want i have h23 injectors i could sell you, i thought was gonna use them, but guessed wrong. don't know the flow tho
Old Feb 3, 2004 | 05:56 PM
dfoxengr's Avatar
Default Re: (Bolivianstrtwpn)
100 is kinda expensive. ynot just get DSM auto (green tops?) theyre like 345cc or something and like 50 beans
Old Feb 3, 2004 | 06:15 PM
Casey's Avatar
whats a good price for 97+ prelude injectors then? i figured that was a good price?
Old Feb 3, 2004 | 06:25 PM
JDogg's Avatar
Default Re: (Casey)
100 bux is fair for 97+ 290cc h22 injectors, they are getting harder and harder to find.
h23 injectors are 240cc.
i know where some 310's are in raleigh for 200 bux if you want those.
chances are 280 or 290's arent gona be big enough. those tend to max out at around 190hp at 8200 rpms.
Old Feb 3, 2004 | 06:42 PM
Casey's Avatar
Default Re: (JDogg)
brad said i could stay with my stock injectors and run 60psi. I want a little more insurance than that. as for my setup:
jdm gsr
11.4:1
rlz stage 2 cams
rlz stage 2 pnp
intake
an-r header, no exaust
skunk2 IM
ericks 68-66 tb
hondata
b&m regulator
Old Feb 3, 2004 | 08:01 PM
JDogg's Avatar
Default Re: (Casey)
it would prolly take more than 60psi to do it on stock injectors.
on the last b20vtec i did we were running 55psi fuel pressure, making 195hp, reving to 8500 rpms and the prelude 290cc injectors were really close to maxed out, around 90%.
not sure what those cams will do but i would guess you will have more power than that b20vtec, not to mention more revs
Old Feb 4, 2004 | 02:33 PM
ITRswapandslow's Avatar
dude, i JUST told you to get auto DSM's
they're 390
you ******* rice boy stunnnnnnaaa
Old Feb 4, 2004 | 03:28 PM
Casey's Avatar
Default Re: (ITRswapandslow)
yeah rob, sure ya did, better be careful and not waste those 5 posts a day
Old Feb 16, 2004 | 04:44 PM
1fast5gp's Avatar
Pmed about injectors.. i got 290CC prelude injectors.. 100 bucks takes them!!! only 50K on it.. out of a 00 prelude..
girliehonda
May 19, 2007 07:28 AM
Tad
Oct 23, 2004 10:27 PM
B_1_8_hatch
May 6, 2003 04:34 PM
