Brake questions
Old Feb 3, 2004 | 09:55 AM
Soon_2b_evil's Avatar
Default Brake questions
ok well all this talk around here about people having 300-600Bhp cars around here is good and all that but how do you stop one?
Well i need some new brakes before i drop my new motor in so, with stock wheels whats a good combo?
Rotors
Pads
SS lines
Brake Fulid
anything else im missing?
Old Feb 3, 2004 | 10:02 AM
StyleTEG's Avatar
Default Re: Brake questions (Soon_2b_evil)
http://www.fastbrakes.com/prod...g1175
Out of everything you listed, only the brake pads are going to be increasing brake torque.
Old Feb 3, 2004 | 11:25 AM
Default Re: Brake questions (StyleTEG)
wow thats alot of $$.
something i dont have right now.
Old Feb 3, 2004 | 11:50 AM
rapid_roy's Avatar
Solid rotors/Cobalt pads/good brake fluid are all you need.
Cheees,
Sean
Old Feb 3, 2004 | 06:50 PM
StyleTEG's Avatar
Default Re: Brake questions (rapid_roy)
Honestly, for a car that is looking to have 300-600hp (from what his post says), I think more brake torque is necissary.
Cobalts street pads will help, but I would still opt for a larger piston caliper or a larger diameter rotor.
Old Feb 3, 2004 | 06:58 PM
Kendall's Avatar
I agree that more braking torque is necessary. A caliper upgrade is definately recommended.
Old Feb 3, 2004 | 07:33 PM
crxsirvtec's Avatar
what car is this going in??
i used prelude vtec rotors and type R calipers on my CRX...
Old Feb 3, 2004 | 07:59 PM
Default Re: Brake questions (crxsirvtec)
00si
Old Feb 3, 2004 | 08:52 PM
Sliced Beard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsirvtec &raquo;</TD></TR><TR><TD CLASS="quote">
is it just me or are you missing two lug nuts
you need to get some before your wheel falls off
Old Feb 4, 2004 | 01:04 PM
crxsirvtec's Avatar
Default Re: Brake questions (dirtyd463)
that was just a test fit...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote">
you need to get some before your wheel falls off</TD></TR></TABLE>
Old Feb 4, 2004 | 01:42 PM
Boostin'RPS13's Avatar
stopping is alot more important in my book than hauling ***. I dont know if your building a street car or track car but you should definatly put your brake setup into thought as one of the first things you do.
Old Feb 4, 2004 | 03:48 PM
rapid_roy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StyleTEG &raquo;</TD></TR><TR><TD CLASS="quote">Honestly, for a car that is looking to have 300-600hp (from what his post says), I think more brake torque is necissary.
Umm, no. A 2600lb car going 100mph will take x number of feet to stop regardless of how much HP the engine has.
If his current rotors have enough force to lock up his wheels than he has all the braking power he needs. It doesn't matter if the motor makes 100 or 1000hp. The physical principles involved are the same.
Cheers,
Sean
Old Feb 4, 2004 | 04:17 PM
notsure's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rapid_roy &raquo;</TD></TR><TR><TD CLASS="quote">
Cheers,
Sean</TD></TR></TABLE>
but with more power he will be able to get to 100 mph a lot faster. its a lot easier to get yourself into trouble with a 500hp hatch then it is with 97hp.
Old Feb 4, 2004 | 04:32 PM
Kendall's Avatar
Default Re: Brake questions (notsure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notsure &raquo;</TD></TR><TR><TD CLASS="quote">but with more power he will be able to get to 100 mph a lot faster. its a lot easier to get yourself into trouble with a 500hp hatch then it is with 97hp.</TD></TR></TABLE>
Exactly what I was thinking. Also, it's easier to lose track of a more powerful car and go faster/farther than you would ordinarily intend to. When this happens, a bit of extra braking force certainly couldn't hurt.
Old Feb 4, 2004 | 06:13 PM
Dan GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsirvtec &raquo;</TD></TR><TR><TD CLASS="quote">what car is this going in??
what front knuckles you using to fit these brakes?
Old Feb 4, 2004 | 06:45 PM
crxsirvtec's Avatar
Default Re: Brake questions (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">
what front knuckles you using to fit these brakes?</TD></TR></TABLE>
90-91 Civic EX (only avail in the US)
it's the Sedan model with the Si motor
Old Feb 4, 2004 | 07:08 PM
Dan GSR's Avatar
the caliper bracket fit the knuckle just fine?
i may have to do this to my friend's car
Old Feb 4, 2004 | 07:12 PM
Lo-Buck EF's Avatar
dont touch my car. it doesnt need to be anymore illegal.............plus i like my 13's and 14's
zakarylakota
Dec 30, 2018 06:12 PM
user 93082343
14
Mar 23, 2009 02:49 PM
totaled
Jan 22, 2003 06:04 PM
EG6-SiR
10
Sep 10, 2001 07:19 AM
