Need Brake Fluid Help.. FAST!!!
Guys, I need a question answered. I'm basically on my way to the dealer for my 30,000 mile service. I purchased some Motul DoOT 5.1 brake fluid to install...but reading my owners manual this morning I come across this...
"Brake fluid marked DOT 5 is not compatible with your vehicle's braking system and can cause extensive damage."
This has me a little worried. From what I have heard other people are using this fluid, can somebody please confirm that this will be okay or should I just have the OEM fluid put in?
This link shows that 5.1 is indeed compatible with Honda braking system. (So are DOT 2 and 4 fluids). Scroll down to the bottom.
https://honda-tech.com/zerothread?id=70315
Flux - did you get it changed? How does it feel now? Did you alway swap the brake pads??
[Edit] alway = also [/Edit]
[Modified by Cosworth, 8:05 PM 10/6/2001]
