is flywheel resurfacing a MUST?
Old Feb 3, 2004 | 07:41 AM
igo4bmx's Avatar
Default is flywheel resurfacing a MUST?
I'm wondering because I bought a OE Mflywheel with about 20k miles on it...
just wondering it its always necessary, and how much do they run?
Old Feb 3, 2004 | 07:44 AM
5thgencivic's Avatar
Default Re: is flywheel resurfacing a MUST? (igo4bmx)
It's usually a good idea when changing the clutch or in a situation like yours. It usually runs around $30-$35
mrnicolas's Avatar
it would be a good idea since it is out of the car. I just got mine done for $40. Think of it as "insurance" that it is in good shape.
Old Feb 3, 2004 | 07:45 AM
GSRwBOOST's Avatar
Default Re: is flywheel resurfacing a MUST? (mrnicolas)
sure. if you like the clutch you just boughtt.
Old Feb 3, 2004 | 08:19 AM
owen_the_soyboy's Avatar
Default Re: is flywheel resurfacing a MUST? (GSRwBOOST)
depends on how bad it is now, depends on how hard you romp the clutch and shift nd depends on how much power your car makes.
I never resurfaced mine (at 100k miles) when I installed a clutch and it didnt effect the clutch for the next 30k miles... so I'd say if it looks good and measures flat, youre good to go.
Old Feb 3, 2004 | 08:24 AM
CHONCH's Avatar
as long as you don't see a bunch of heat-tempered areas (bluing and such) on the surface, and as long as it is flat, then you have no worries.
but if you're going through the trouble of putting a clutch in, you might as well have the flywheel re-surfaced. the local autozone here in my area does it for free....
Old Feb 4, 2004 | 01:49 AM
Vtec92Civic's Avatar
yeah I heard it was a good thing to do, but it does not always have to be done.
Old Feb 4, 2004 | 01:57 AM
T.J.'s Avatar
If it is a brand new clutch it needs to be done. Its not very expensive to have done i think i useually get my done for like 25-30 bucks but you can expect up to about 40.
Old Feb 4, 2004 | 06:31 AM
yellow_jacket's Avatar
Default Re: is flywheel resurfacing a MUST? (Skunk2whore)
if it is not done sometimes it will wear the clutch out rather quickly.
Old Feb 4, 2004 | 06:51 AM
93CivicSI's Avatar
Ditto, everyone that says to do it while you have access to it!!
Old Feb 4, 2004 | 07:23 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: is flywheel resurfacing a MUST? (93CivicSI)
get it done so you know you have a full contact patch ...because if you install it and you dont...then imagin all the work you have to do to take it out to do something you should have done at the begining...feel me..
Old Feb 4, 2004 | 07:24 AM
xerox445's Avatar
I would always get it done, is it worth putting a brand new clutch in, only to have it chatter and wear faster to save 40 bucks?
Old Feb 4, 2004 | 07:27 AM
esoterEK..'s Avatar
Default Re: (xerox445)
cost me $50 and it was hard as hell ot find a place here in NC.. had to ask around 3 shops . Do it while you have access to it i would say... unless your BROKE
huntarrr
18
Feb 4, 2006 11:21 PM
93h22a1vtec
Jan 10, 2006 09:27 PM
JdmAcclude
Aug 4, 2004 12:51 AM
AznBlueBoy
Jun 25, 2004 12:41 AM
piotrush
May 18, 2004 06:04 PM
