What Type Of Clutch
Old Feb 3, 2004 | 06:57 AM
KimChiKid's Avatar
Default What Type Of Clutch
what is a suggestion on a clutch for a 2001 B20 Setup?
Using
Ls - ?
Si - ?
GS-R - ?
Old Feb 3, 2004 | 06:59 AM
gezer's Avatar
Default Re: What Type Of Clutch (KimChiKid)
act 6 puck with heavy duty pressure plate handle alot of power just so you wont have to change it again down the road, u never know u might be putting out alot of power someday
Old Feb 3, 2004 | 07:45 AM
GSRwBOOST's Avatar
Default Re: What Type Of Clutch (gezer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezer &raquo;</TD></TR><TR><TD CLASS="quote">act 6 puck with heavy duty pressure plate handle alot of power just so you wont have to change it again down the road, u never know u might be putting out alot of power someday </TD></TR></TABLE>
but until then if you drive in a lot of traffic... go with a sprung clutch fullface and an easy pressure plate...
save your leg.
Old Feb 3, 2004 | 07:58 AM
thenick's Avatar
Default Re: What Type Of Clutch (GSRwBOOST)
im personally going to go with a clutchmasters stage 1. heard nothing but good things from CM and ACT
Old Feb 3, 2004 | 08:02 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: What Type Of Clutch (ixiblindixi)
the act has alot of pedal pressure and is hell on the thrust bearings. i have a cm stage 4, it is not real forgiving, but it is a sprung clutch and has a a little give. the act is great but is hell on the thrust bearing. i have been a cm **** and like their product. n/a b20 a stage 3 should be fine. if you decide to go boosted, maybe a 4 later on.
Old Feb 3, 2004 | 08:03 AM
Filliam H. Muffman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRwBOOST &raquo;</TD></TR><TR><TD CLASS="quote">
save your leg.</TD></TR></TABLE>
driving in traffic with a heavy duty pressure plate is death on your leg unless you're a body builder.
Old Feb 3, 2004 | 11:13 AM
KimChiKid's Avatar
Default Re: What Type Of Clutch (JUN EK9)
So go with an ACT or CM stage 1-3?
Because it is a daily driven car I just want something that will respond a lot better than my stock LS clutch kit.
Old Feb 4, 2004 | 01:44 AM
Vtec92Civic's Avatar
I would say stage 1 or 2 clutch would be good . . . don't over kill unless you are putting down some serious power.
Old Feb 4, 2004 | 04:41 AM
ki3t's Avatar
This user can set his title.
I know what you mean man. Driving in NYC with that kinda clutch Sucks big time.
Back to the topic. Get a clutchmaster.
Old Feb 4, 2004 | 01:42 PM
KimChiKid's Avatar
Default Re: What Type Of Clutch (Ki3t)
Stage 2 clutch masters sounds good thanks guys!
turbo18coupe
Sep 26, 2007 04:49 PM
M.A.R.C.
Jan 1, 2006 09:38 PM
PhiLG
Oct 30, 2004 10:12 PM
integra-modder
Jul 25, 2002 05:31 AM
shamoo
Feb 7, 2002 02:09 AM
