disabling the EGR system - possible?
Old Feb 3, 2004 | 06:53 AM
Greyout's Avatar
Default disabling the EGR system - possible?
Originally, the idea was to remove the entire EGR system, and then run a chipped GS-R ECU w/ a VAFC.
However, Improved Touring rules say no piggybacks. Soooo, that rules out the VAFC.
so I two Questions -
1: with a GS-R ECU, would I be adding or removing fuel on the VAFC when tuning? If adding, would I be able to tune it with fuel pressure alone?
and if not....
2: What is the best way to make the ECU think the EGR is functioning? Would I have to wire up some kind of relay-resistor combo?
Any other ideas?
Old Feb 3, 2004 | 07:06 AM
NoLipRacen's Avatar
Default Re: disabling the EGR system - possible? (Greyout)
the p72 makes the car run lean so you would to add fuel, the fpr only alters pressure not the volume (i think?). and as for the resistor im really not sure.
Old Feb 3, 2004 | 09:08 AM
Greyout's Avatar
Default Re: disabling the EGR system - possible? (LudeTuner)
hmmm, thanks for the info. With a given injector pulse, me thinks that increased fuel pressure will result in more fuel per pulse. Guess I'll give it a try
Old Feb 3, 2004 | 11:26 AM
prelude_angel77's Avatar
You could also run a chipped P28 with an obd2-1 harness. (Assuming its a 97+ lude). Good fuel map and with the right chip you could have adequate performance without the ecu looking for the egr.
Old Feb 3, 2004 | 12:24 PM
thehondaguru's Avatar
Default Re: disabling the EGR system - possible? (Nips)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nips &raquo;</TD></TR><TR><TD CLASS="quote">You could also run a chipped P28 with an obd2-1 harness. (Assuming its a 97+ lude). Good fuel map and with the right chip you could have adequate performance without the ecu looking for the egr.</TD></TR></TABLE>
Yes but be careful and make sure your air/fuel mixture is good because the p28 has no knock sensor. It could be deadly if the engine isnt tuned right.
oryanh
Mar 25, 2003 03:57 PM
ArchAngel Sabastian
Jan 3, 2003 08:13 AM
Lowez
Jul 15, 2002 11:50 PM
Toda Party
Mar 17, 2002 01:39 AM
