Were to get this? 2,5" converter
Old Feb 3, 2004 | 06:16 AM
YashiMotors's Avatar
Default Were to get this? 2,5" converter
Hi!
I need a couple of these? Where can get them? Must to be 2.5".
Old Feb 3, 2004 | 06:49 AM
b18c1_powered_si's Avatar
Default Re: Were to get this? 2,5" converter (John_Doe)
th'ats a flange u need or the whole cat?
Old Feb 3, 2004 | 06:56 AM
QuanKwan's Avatar
inlinefour has them
TheGSRGuy's Avatar
Default Re: Were to get this? 2,5" converter (b18c1_powered_si)
http://www.inlinefour.com
You took pictures from their site....I fail to see why you need to know where to get it.
Old Feb 3, 2004 | 07:11 AM
Default Re: Were to get this? 2,5" converter (TheGSRGuy)
i just found the picture on the net
Old Feb 3, 2004 | 08:18 AM
yellow blur's Avatar
jdmhondaparts carries them.
Ed
Old Feb 3, 2004 | 09:07 AM
DsITR's Avatar
http://www.kteller.com/store/ try there
or IM Kteller
Old Feb 3, 2004 | 10:57 AM
Rhetoric's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheGSRGuy &raquo;</TD></TR><TR><TD CLASS="quote">http://www.inlinefour.com
You took pictures from their site....I fail to see why you need to know where to get it.</TD></TR></TABLE>
Old Feb 3, 2004 | 11:43 AM
itr1244's Avatar
ok. if i wanted to weld the flange on universial cats do i use
or
or both will work?
i may have to add
Old Feb 3, 2004 | 12:00 PM
Phoenix_ITR's Avatar
Default Re: Were to get this? 2,5" converter (itr1244)
i believe you'd have to use the flared flange for the front of the cat so that it can make a tight seal with the donut gasket on the header.
Old Feb 3, 2004 | 12:04 PM
96dc2's Avatar
With the first flange, you need it to be at a certain angle to match your header. With the second one, they flare some tubing then weld it onto the cat with the flange "floating" between the flared portion and the cat.
The first one is said to promote a better seal. But the second one gives you more flexibility when bolting on the cat where you might have to do some rotating to it.
Old Feb 3, 2004 | 12:20 PM
itr1244's Avatar
Default Re: Were to get this? 2,5" converter (96dc2)
i dont know .. i guess i probably go with the first one..
the 2nd one's too ghetto.
haha hey guys which cat will have better chance passing emition ? test?
magnaflow cat, carsound cat? or are there any other cat availble on market other than those 2?
thx
Old Feb 3, 2004 | 12:44 PM
01CWITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">i dont know .. i guess i probably go with the first one..
thx</TD></TR></TABLE>
should go with carsound cat...
Old Feb 3, 2004 | 12:52 PM
the hell with the emission test i just want a test pipe for my new 4-1 DC JDM, we have a lot of trees here in sweden that pump out oxygen.
Old Feb 3, 2004 | 10:49 PM
96dc2's Avatar
Carsound is the maker of Magnaflow products. So the cats would essentially be the same.
1badteg
Mar 31, 2007 12:47 PM
hatchinprogress
Mar 19, 2006 03:17 PM
mugenhatch92
May 20, 2005 10:25 AM
importboi22
Nov 25, 2004 09:30 AM
White Smoke
Oct 6, 2003 12:17 PM
