OEM Parts number for injectors
Symptons: Gasoline leaks right underneath the injector onto the skunk2 mani., which i beleive is because i used the stock orings (85k miles)...
So I figure I need to replace the o-rings on my injectors, after recently upgrading to an AEM fuel rail/FPR. What would the part number/site be? Or just the site, i'll find it myself, thanks
Yeap just checked out http://www.hondautomotiveparts.com ... the part comes up as the Injector Seal Ring.
Now look it up on the INTAKE MANIFOLD parts diagram and you'll see that it matches up to the lower grommet for like $4.xx. That's not the same as the upper o-ring, which is what I think you're looking for considering that the lower grommets can't leak fuel.
Even the part reference number will match.
