Sway bars: OEM or Aftermarket?
Old Feb 3, 2004 | 01:19 AM
jonyb's Avatar
Default Sway bars: OEM or Aftermarket?
What are the opinions on the best sway bar for a DC2?
Old Feb 3, 2004 | 01:30 AM
uNF$@#!'s Avatar
Default Re: Sway bars: OEM or Aftermarket? (jonyb)
obviously the one that works best with your suspension to give you handling that suits your taste
Old Feb 3, 2004 | 07:05 AM
Flux's Avatar
Default Re: Sway bars: OEM or Aftermarket? (Soup ****)
It really does depend on the rest of your set up and what you prefer as a driver. I am currently running the JDM 23mm rear bar with the stock front bar and this balances nicely with the rest of my suspension. I know lots of other people that use a combination of the larger Mugen bars.
You really need to look at it from a wider perspective and not just a single piece of equipment at a time.
Old Feb 3, 2004 | 07:11 AM
Chris N's Avatar
Default Re: Sway bars: OEM or Aftermarket? (Flux)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">
You really need to look at it from a wider perspective and not just a single piece of equipment at a time.</TD></TR></TABLE>
In addition to some description of the intended use of your car.
There is never a catch-all solution that works well for everyone.
Old Feb 3, 2004 | 07:58 AM
BudMan's Avatar
Default Re: Sway bars: OEM or Aftermarket? (Chris N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">
There is never a catch-all solution that works well for everyone.</TD></TR></TABLE>
Definately having an understanding of the limits of your car is important...going to a larger bar can cause a dangerous driving condition if you are not careful.
Old Feb 3, 2004 | 01:38 PM
jonyb's Avatar
Default Re: Sway bars: OEM or Aftermarket? (BudMan)
Well here's the deal. I took a stripped down 99 GSR, cut it in half, and clipped it with a 98 JDM ITR clip. The front sway is stock. My concern is, the rear is a stock GSR. I've got Apexi WS coilovers (thanks Area51), and every bushing that Energy makes. I was wondering if I should match the front with the rear, or go aftermarket. I don't really have big plans for the car as far as auto cross, but I'd like it to handle pretty good.
Rob.
Suspension & Brakes
20
Nov 27, 2006 09:20 PM
nek9
12
May 16, 2006 08:59 PM
rival12
Sep 26, 2005 08:30 PM
Mark
Oct 17, 2003 10:25 AM
Typel2
Aug 11, 2002 01:21 PM
