clutch cable and throttle cable too short perhaps? b16a crx
Old Feb 2, 2004 | 08:53 PM
Origin's Avatar
Default clutch cable and throttle cable too short perhaps? b16a crx
well ive read about how you need the integra throttle cable, which i got, and i also heard that the stock crx clutch cable will work. well i put the throttle cable on, and i figure i have this thing hooked up right, maybe not but i seems that its as tight as it will go but i still have slack in it. you tell me what you think
http://www.we-todd-did-racing....D.jpg
do i just have it screwed on wrong?
now to the clutch cable. i heard many people say you can use your stocker. well i did, and found that it was so short i couldn't get it to even loop into the arm. so i read up and someone said to just take the arm off and then put the cable in it then tighten all of it back down. and i did and it seems like it worked. i pushed the clutch in and shifted the gears, everything felt nice. then i notice that my clutch is depressed and i can still shift. i loosened the cable as much as i can, but it still will not dissengage. heres some pictures
anyone know wtf im doing wrong?
Old Feb 2, 2004 | 09:07 PM
kid-honda's Avatar
The throttle cable looks good, its supposed to be loose. Any tighter and the throttle will stick.
I used the stock clutch cable but I also ran it behind the motor for looks which probly also gave it some more slack but my stock cable worked perfect and has for 3 years.
Old Feb 2, 2004 | 09:38 PM
Origin's Avatar
Default Re: (kid-honda)
i noticed you have an si. the si clutch cable isn't longer by chance is it? i have a crx hf
Old Feb 2, 2004 | 09:39 PM
kid-honda's Avatar
Default Re: (Origin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Origin &raquo;</TD></TR><TR><TD CLASS="quote">i noticed you have an si. the si clutch cable isn't longer by chance is it? i have a crx hf</TD></TR></TABLE>
They should be identical.
Old Feb 2, 2004 | 10:39 PM
91civicEX's Avatar
Default Re: clutch cable and throttle cable too short perhaps? b16a crx (Origin)
the car was on when you went through all the gears with the clutch up right?
Old Feb 3, 2004 | 05:42 AM
Origin's Avatar
Default Re: clutch cable and throttle cable too short perhaps? b16a crx (91civicLX)
no, the wiring for the car was still in progress so the car couldn't have been started. i was just testing it out cause i just hooked up the shift linkage and clutch cable. i wanted to see how it felt and thats when i found out that i could shift with the clutch disengaged.
Old Feb 3, 2004 | 06:37 AM
kid-honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Origin &raquo;</TD></TR><TR><TD CLASS="quote">no, the wiring for the car was still in progress so the car couldn't have been started. i was just testing it out cause i just hooked up the shift linkage and clutch cable. i wanted to see how it felt and thats when i found out that i could shift with the clutch disengaged.</TD></TR></TABLE>
You should be able to shift without the clutch when the car is off.
Old Feb 3, 2004 | 06:58 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Not sure of the accuracy of this but,
From what I have read,the stock cable had to be altered as in this picture..
Modified by 88DXCRX at 6:45 PM 3/19/2008
Old Feb 3, 2004 | 07:10 AM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
stock should work....from what i hear.....try to run the cable a different way....under and over....haha....
Old Feb 3, 2004 | 10:16 AM
Origin's Avatar
Default Re: (dgonzals)
well i don't think it how i ran the cable because there is plenty of slack to move it all around but as far as the adjustable part its as loose as it will go. but maybe being able to shift while the car is off is my problem. but wouldn't i have to still push the clutch in to make it to where i could shift?
Old Feb 3, 2004 | 11:33 AM
keebler65's Avatar
i had the exact same problems that you are having.
i solved the clutch problem by caughing up some extra money and getting a 1990 integra clutch cable. it was the perfect length plus it was nice to have a new cable - it felt better than my worn out one.
on to the throttle....i used an integra one as you did and also ran into the same problem. in your pics it looks as though its not tight enough, which means you wont get wide open throttle (and you know what that means...). i found out that you can shift the bracked to the right and then use a piece of metal to prevent it from coming loose (that way it can still be fastened with two screws and instead of one). here is a pic to better explain:
its really easy to do....shouldnt take more than 10 minutes to drill up a piece of metal. hope that helps....btw nice camera you got there
Old Feb 3, 2004 | 11:38 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Origin &raquo;</TD></TR><TR><TD CLASS="quote">but maybe being able to shift while the car is off is my problem. but wouldn't i have to still push the clutch in to make it to where i could shift?</TD></TR></TABLE>
No . . .
Old Feb 3, 2004 | 06:14 PM
Origin's Avatar
Default Re: (Targa250R)
first manual ive owned, so after finding that out im pretty sure the clutch cable will work. at least i hope so. also im gonna see about getting that throttle cable braket a try. hopefully that should be what i need.
oh and thanks about the comment about the camera. i love it.
86crxintheworks
12
Jan 13, 2008 07:22 PM
ironchef25
10
Jan 20, 2004 12:26 PM
sCeRaXn
Mar 3, 2003 05:46 PM
CRexcellence
Dec 11, 2002 03:12 AM
BoostinDC2
Feb 17, 2002 05:41 PM
