Engine oil Q?
Old Feb 2, 2004 | 08:28 PM
L8apex's Avatar
Default Engine oil Q?
Question for all you engine gurus. I've been using Mobil1 5W30 in my stock B16A and I am burning oil. Thinking of switching oil but should I stick with Mobil1 10W30, or go to Castrol GTX 5W30? Is it possible to switch back to conventional oil after synthetic. FYI, I've been using Castrol for the first 100,000 km before I switched to synthetic 37,000 km ago. Thanks in advance.
Old Feb 2, 2004 | 08:31 PM
Kendall's Avatar
Yes you can switch back without any adverse affects. Also, B-series engines like to burn Mobil-1 oil for some odd reason.
Old Feb 2, 2004 | 08:41 PM
ejprimo's Avatar
Default Re: (Kendall)
you can switch back and forth b/w dino and syn. try castrol high mileage 10w-30. its only 50-75 cents more a quart than regular gtx and it has a thicker viscosity than castrol gtx so it may help a little with the oil burning issue.
Old Feb 2, 2004 | 08:57 PM
L8apex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Yes you can switch back without any adverse affects. Also, B-series engines like to burn Mobil-1 oil for some odd reason.</TD></TR></TABLE>
Really? Is this a known fact? I just thought VTEC engines (H22s in particular) burn oil, regardless of brand. Thanks for the info guys.
Old Feb 3, 2004 | 03:59 AM
HT Chaplain's Avatar
Loved
Default Re: (L8apex)
I heard on here a couple months ago someone with the same problem and they switched to Castrol Syntec and it doesnt burn oil anymore. You might want to try that.
AuroraHonda
Sep 13, 2009 03:22 PM
goheel
Feb 20, 2007 03:24 PM
danny98r
Nov 10, 2004 07:08 AM
hECtUbiS
Oct 20, 2004 05:27 AM
mattmw88
Apr 29, 2004 01:52 PM
