what's the best flywheel?
Old Feb 2, 2004 | 06:47 PM
kool168's Avatar
Default what's the best flywheel?
what is the best and light weight flywheel?
cheap and good suggestion will be the best
does those flywheel and be able use with other band's clutch? such as ACT clutch and spoon flywheel combination.
Old Feb 2, 2004 | 07:13 PM
TeamNextGenChris's Avatar
Default Re: what's the best flywheel? (SOL-R)
i'va used and installed quite a few Fidanza flywheels with no problems,been very happy.i believe Fidanza makes Clutchmasters' flywheels also.
pretty much any reputable manufacturer's flywheel should be good,and all that i've seen are stock spec as far as the shoulder height and everything else,so they can be used with any clutch.
chris
Old Feb 2, 2004 | 07:40 PM
Bailhatch's Avatar
Default Re: what's the best flywheel? (TeamNextGenChris)
I have installed about 10 of the ACT Xact forged chromolly FWs. they are really nice and are reasonably priced IMO. AASCO, CM, spoon etc... don't compare for the $
Old Feb 2, 2004 | 07:44 PM
The Internet Tough Guy's Avatar
Default Re: what's the best flywheel? (Bailhatch)
my act prolite is a beautiful thing. only 200 bucks too
Old Feb 2, 2004 | 07:50 PM
ATS*Mark's Avatar
OG triple OG
Default Re: what's the best flywheel? (jwn7)
i want one
Old Feb 2, 2004 | 07:52 PM
Soccerking3000's Avatar
Default Re: what's the best flywheel? (Hella_JDM)
what do you say to taking a stock flywheel and grinding it down?? has anyones done this with good results
Old Feb 2, 2004 | 08:10 PM
B18bEK's Avatar
Default Re: what's the best flywheel? (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">what do you say to taking a stock flywheel and grinding it down?? has anyones done this with good results</TD></TR></TABLE>
the one i got with my motor looked completely trashed - heat spotted like crazy. just took the sander pad air tool thingy to it and walaa, a perfect flywheel.
Old Feb 2, 2004 | 08:13 PM
NonovUrbizniz's Avatar
Loved
You should have a machine shop lathe it for you...
And make sure they balance it afterwards...
Also don't go too light with that... if you shave off too much material it loses a LOT of it's integrity..
My buddy has a stock "shaved" flywheel in his VW... it's a little too light and it combined with a larger TB makes his car stall when it tries to drop into idle.
They work but aren't ideal... I'd spend the money if you can.
Old Feb 2, 2004 | 08:16 PM
B18bEK's Avatar
i didn't shave mine for weight, i just resurfaced it i guess to get rid of the heat spots ... not sure if thats what you were asking or not.
Old Feb 2, 2004 | 08:18 PM
Default Re: what's the best flywheel? (NonovUrbizniz)
well i have a stillen flywheel and it weighs 9 pounds and it awesome, i want to try and take my stock one and grind it down so if need be for some reason i need to put it back ini do not lose the fun driving with the lightened one
Old Feb 2, 2004 | 08:24 PM
B18bEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">well i have a stillen flywheel and it weighs 9 pounds and it awesome, i want to try and take my stock one and grind it down so if need be for some reason i need to put it back ini do not lose the fun driving with the lightened one</TD></TR></TABLE>
aren't you getting turbo soon? most people don't run that light of a flywheel with turbo applications
Old Feb 2, 2004 | 09:48 PM
kool168's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 &raquo;</TD></TR><TR><TD CLASS="quote">my act prolite is a beautiful thing. only 200 bucks too</TD></TR></TABLE>
wow... i want that good deal too
where did you buy it from and it's new or used? also wut's the weight of the flywheel?
Old Feb 2, 2004 | 11:10 PM
someone had a deal in the sponsor marketplace. 8.8 lb chromoly. very fun
Old Feb 2, 2004 | 11:17 PM
kool168's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 &raquo;</TD></TR><TR><TD CLASS="quote">someone had a deal in the sponsor marketplace. 8.8 lb chromoly. very fun </TD></TR></TABLE>
good deal
hope i can get one like yours
kool168's Avatar
so any more suggestioins of lightweight, cheap and good quality flywheel?
Old Feb 2, 2004 | 11:18 PM
JDMproject17's Avatar
http://www.noredline.com
the best resufracing for flywheel
Old Feb 2, 2004 | 11:23 PM
ExospeedAMcrx's Avatar
Default Re: (JDMproject17)
check these ones out: 7.9lbs
https://honda-tech.com/zerothread?id=742103
Modified by exospeedAMcrx at 2:06 AM 2/6/2004
Old Feb 2, 2004 | 11:56 PM
sollude's Avatar
ihavea fidanza flywheel in my engine and its very nice but a litte pricey but its worth the money mine was $300 but it wasnt for a sol engine it was for my jdm h22 engine that i have in my sol but i wouldnt think that they would have a different price for a different engine
Old Feb 3, 2004 | 07:01 AM
Default Re: what's the best flywheel? (B18bEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18bEK &raquo;</TD></TR><TR><TD CLASS="quote">
aren't you getting turbo soon? most people don't run that light of a flywheel with turbo applications </TD></TR></TABLE>
i run a 7lb flywheel with my turbo.love it.
chris
Old Feb 3, 2004 | 07:26 AM
B18bEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">
chris</TD></TR></TABLE>
cool, just don't see many people with them ... are you running a smaller turbo? like the greddy kit?
Old Feb 3, 2004 | 07:30 AM
WAFFLES's Avatar
The lightest flywheel I've seen is the Comptech flywheel. It weighs around 6.5lbs.
Not sure about the price.
Old Feb 3, 2004 | 07:31 AM
cool, just don't see many people with them ... are you running a smaller turbo? like the greddy kit?</TD></TR></TABLE>
no,it's the FMAX kit-T3/T4,not sure what trim.everything i've ever read points to super-light flywheels being an advantage with turbos.
chris
Old Feb 3, 2004 | 11:29 AM
i am only runnigna small 14b so i don't think it will be a problem at all
Old Feb 3, 2004 | 12:07 PM
NAB16AEK's Avatar
I have the act streetlite(12 Lbs). reliable, but really didn't notice difference in throttle response or noticeable power gains between it and stock. If i could do it again i would go prolite(8 lbs.)
Old Feb 4, 2004 | 08:30 PM
kool168's Avatar
Default Re: what's the best flywheel? (NAB16AEK)
then how heavy is spoon's?
