CTR .25 Overbore pistons in b16a2?
Old Oct 5, 2001 | 08:13 PM
BodyKits NW's Avatar
Default CTR .25 Overbore pistons in b16a2?
Someone is selling a short block with these pistons installed in a b16a2. Someone told me that it would be close to 1.8 liters. Does someone know exactly what compression it would yield with a b16 head, and also the amount of liters the engine will be? Thanks guys.
Old Oct 5, 2001 | 08:20 PM
nomorecrx's Avatar
New User
Default Re: CTR .25 Overbore pistons in b16a2? (BodyKits NW)
it would still be 1.6 liters. compression would be the same as a b16b. 11.4:1, if my memory serves me right.
Old Oct 5, 2001 | 08:41 PM
RagingAngel's Avatar
Default Re: CTR .25 Overbore pistons in b16a2? (nomorecrx)
I thought the CR in the 16B was 10.8:1??
Old Oct 6, 2001 | 06:35 AM
FAST4DR's Avatar
Default Re: CTR .25 Overbore pistons in b16a2? (RagingAngel)
CR should be 11:1
cc would be a little over 1600
Old Oct 6, 2001 | 06:48 AM
nomorecrx's Avatar
New User
Default Re: CTR .25 Overbore pistons in b16a2? (FAST4DR)
i know i have seen 10.8:1 before, but i believe that is wrong. the jdm itr is 11:1 and the ctr compression ratio is suppossed to be higher than that. at least that is what i was told. as i said before i might be wrong. i know the block is 1.6 liters though.
Old Oct 6, 2001 | 07:23 AM
FAST4DR's Avatar
B16B CR is 10.8:1
ITR JDM CR is 11.0:1 (due to pistons)
ITR USDM CR is 10.6:1
USDM B16A3 is 10.2:1
Old Oct 6, 2001 | 09:11 AM
sgT's Avatar
sgT
JDM ITR = 11.1:1
Old Oct 6, 2001 | 09:12 AM
Alright, so it doesn't raise the compression too much. I guess it would be nice to get some CTR cams in there too. What would raise it in the 11:1 range. Also I knew it would not be that simple to raise the amount of liters the engine would be. If it was that simple then people would be doing it more often and not buying those expensive stroker kits.
Old Oct 6, 2001 | 10:21 AM
AJ PwR's Avatar
CTR Overbore pistons in B16A will be around 11.5:1
Old Oct 6, 2001 | 12:46 PM
Mike K's Avatar
Default Re: CTR .25 Overbore pistons in b16a2? (AJ PwR)
don't waste your time with a 1.6 block. no torque.
oh, and assuming the head is not milled, block is not decked, and headgasket thickness is stock, your compression will be 11.19:1
displacement is a paltry 1605cc. uhh... now THAT'S a torque monster.
kantfadedisazn
12
Sep 7, 2006 07:35 PM
JDM978
Oct 10, 2004 10:31 AM
jsalicru
Dec 20, 2002 03:13 PM
HybriDNA
Aug 28, 2002 08:53 AM
zentraedityper
Jun 16, 2001 04:32 PM
