*HELP* Where can i buy a front lower "A" arm 00' Civic???...CHEAP
Old Feb 2, 2004 | 06:02 PM
^R@m!r0_(M)
Guest
Posts: n/a
Default *HELP* Where can i buy a front lower "A" arm 00' Civic???...CHEAP
Like the title says i need a lower front control arm 00' civic Si if you have one i want it ASAP!!!!
Old Feb 2, 2004 | 06:59 PM
^R@m!r0_(M)
Guest
Posts: n/a
Default Re: *HELP* Where can i buy a front lower "A" arm 00' Civic???...CHEAP (RamiroM)
bump cause i need it bad
Old Feb 2, 2004 | 07:16 PM
TeamNextGenChris's Avatar
http://www.slhondaparts.com/br...=true
51360-S04-A10 ARM ASSY., L. FR. (LOWER) $123.26
if you can't find one on here.i'd also try local junkyards.
chris
Old Feb 2, 2004 | 07:33 PM
^R@m!r0_(M)
Guest
Posts: n/a
Default Re: *HELP* Where can i buy a front lower "A" arm 00' Civic???...CHEAP (TeamNextGenChris)
thank you much... anymore?
Old Feb 3, 2004 | 04:15 AM
dwnthehatch's Avatar
Call Import Auto Salvage and talk to Larry Jr. I just bought a front lca for a teg with the endlink for $55 shipped. http://www.importautosalvage.com
Old Feb 3, 2004 | 04:48 AM
monicle's Avatar
http://www.sohfast.com could probably help you out too but somethimes they can be a bit pricy on certain things
If you didnt need one for an SI then I would have you covered with DX ones but youll need the swaybar attachment.
Modified by monicle at 10:49 AM 2/3/2004
FeedBack159
Honda CR-V & Element
Apr 28, 2013 01:02 PM
killerbee310
Suspension & Brakes
Jan 8, 2006 10:11 PM
S2KP
Feb 23, 2004 10:12 PM
redsidriver
Feb 4, 2004 10:24 PM
